Bitstream vs PCM
Man of Honour
29 Jun 2004
Oxfordshire
Hi guys,
I always think I understand this then read something to contradict what I thought I knew, which then means I realise I know nothing :D
At home I have a Yamaha RV-679 amp, hooked up to a 5.1 set of speakers. My Blu-Ray player, PS4, Xbox One are all hooked up to it and I've always read that I should set each one to output PCM and not Bitstream, as PCM is better due to it being uncompressed. Then on my amp, I have it in 'Straight' mode (not the same as "Pure Direct"). However, I've noticed when watching certain blu-rays that advertise having the DTS HD Master Audio track, that I never get the DTS logo appear on the amp anywhere, so I'm always sat there wondering if I'm missing out and getting second rate audio to what I could be.
Then I read an article this morning that said you should set the media player to Bitstream and let the Amp decode the signal, and that's the only way to get it to use the DTS HD Master track. But surely that makes no sense, as if the DTS HD track is uncompressed, but Bitstream sends compressed audio, then that doesn't make sense?
Could someone please clarify what I should be setting up on what?
Thanks guys :)
LPCM = Audio track is decoded on device playing disc and passed to Receiver as Multi-channel (hence no indicator on receiver as it is no longer a Dolby or DTS data stream)
Bitstream = Audio track is passsed untouched and decoded by receiver (hence the receiver will indicate what type of data stream it is receiving)
There is no right and wrong way, both are giving you HD Audio and it's down to preference. Some argue that the receiver is better configured to decode the streams as it is a specialist audio device dedicated to the process. Others argue that receiver manufacturers play around with the decode to "enhance" certain traits. It really is what sounds best to you.
Remeber you can set your Yamaha receiver to Straight for bitsream sources as well.
If you use PCM then some devices can only send it as a 2 channel signal
For that reason when watching blu-rays I always use Bitstream and then my A/V receiver does the decoding and I can see exactly what audio I am hearing.
Just from anecdotel experience of years of switching and faffing between the two. Ideally PCM sounds far far superior by a country mile.
Perfect, thank you guys
So when they say bitstream is a "compressed" signal, it doesn't mean you're losing quality? I guess that's what I understood it as
And am I right in thinking that for my equipment, which while it isn't naff but is far from the best or pro level, the difference between a compressed DTS/DD track and uncompressed PCM isn't worth worrying about?
If you are passing PCM then your device is decoding the original bitstreams so it is essentially the same. Some blurays (particularly early ones) do/did have optional soundtracks that were entirely uncompressed PCM from source.
Think of DTS/Dolby etc as an MP3, it is compressed audio. As others have said you either allow the player to decode and convert the MP3 to an uncompressed PCM signal or you pass the MP3 to the receiver, which decodes and converts to PCM.
