Bittorrent not connecting to all the peers?
Caporegime
12 Mar 2004
England
For example atm I'm connected to 1/60 out of 4/502, I dont understand why, Ive got port forwarding setup correctly as well, Im using bitcomet ver 0.68. Any ideas?
Ive used that before I find it too cut down, I like BC's interface and it has public DHT features as well. For some reason with UT I kept having to set the max upload rate for every task I did.
ill read out my preferences on bit comet if you want? I usualy am able to max my connection with a decent torrent. :)
1,
max download 600
upload 3
max simul 200
nolimit
5 (advance)
tick
tick
tick
tick
tick
connection
tick
tick
untick
tick
100
63
2
1
auto
300
10
iprules
tick
tick
100
15
cant remember what ive changed so listed main ones for you :) HOpe this helps?
Also use a port around 49k, have been told it helps quite a lot as some isp's are blocking usual torrent ports.
I asked BT about ports and they said they dont block any.
I needed to change the max number of connections per task. It was set to auto, when I changed it to 100 it started to connect to more people
