BitTorrent problem
6 Mar 2008
Stoke area
hello,
I was using BitTorrent to download some game demos and it has been running fine for the last couple of days. The other half wanted to use the PC and was complaining about how long it would take for a webpage to load so I shut BitTorrent down. Everything was running ok and then she started it back up for me after she had finished.
I have just come upstairs to find the BitTorrent screen blank so I restarted it. Again, it loads but comes up with zero torrents.
Checked the log and get the following:
23:23:10: Status: [NatTraversal] list_ports failed with:
Traceback (most recent call last):
File "BitTorrent\NatTraversal.pyo", line 670, in _list_ports
File "BitTorrent\NatTraversal.pyo", line 373, in urlopen_custom
File "<string>", line 1, in connect
error: (10061, 'Connection refused')
23:24:12: [LocalDiscovery] announcing: efad9b2081b511ca4c80f56a6fe20be6bdea7064
23:24:13: [LocalDiscovery] Service u'4d352d302d392d2d623137663738633064653938._efad9b2081b511ca4c80f56a6fe20be6bdea7064._bittorrent._tcp.local.' added
23:24:19: [core.MultiTorrent.infohash_not_yet.peer_id_not_yet] download id unknown/rejected ('83.28.112.114', 3484)
23:24:19: [core.MultiTorrent.infohash_not_yet.peer_id_not_yet] download id unknown/rejected ('88.31.133.42', 1564)
Router and PC have been reset and still nothing. The part downloaded files are showing in explorer at around 4GB in size.
Any help??
