Bizaare 3dmark 03scores
18 Oct 2002
Caerphilly, South Wales
Looks like SLi has been disabled (I assume you have SLi, based on the first score). Try running the CPU test as well and make sure SLi is enabled.
If you don't run the CPU test we can't rule that out ;)
Im not so sure because if you see the first test its clearly 40fps better at 2.8 then the others just die of death ? :confused:
Not too sure if A64's do throttle but thats what it looks like because the first test is faster but it seems as the temps rise the score gets worse, just a thought.
Ben
