I've just finished rebuilding my PC after i put a custom water-loop inside, now here's the bizzare problem: When is started all turned on everything was fine, but it restarted 4 or 5 times after 6 seconds or so (no display on monitor) and finally booted straight into windows on the last try.
I've reset the cmos with the jumper and battery, still the same problem, the PC itself after finally booting generally is working fine, played games on it for the last 20 mins, run prime95, done some memory checks, no problems. I did however notice on first boot-up it said my core speed was 2.5ghz on a lynfield i5 core at 2.66 (http://www.overclockers.co.uk/showproduct.php?prodid=CP-299-IN) then oddly after completely resetting the cmos/battery it's now mysteriously at 2.9 ghz, brainfreeze?
I've no idea what the problem is, i've never updated the BIOS and the machine is 100% working order other than this issue, it's preventing me now to overclock as when i try, the system gives me no display, anyone got any ideas? i'm at a complete loss.
Also when i save settings in the bios, and press F10 to save, the system shuts down rather then restarting, never did this pre-build.
