Hi there
Lots of great monitor deals, some upto £200 cheaper than our competitors, seriously DO NOT MISS OUT ON THESE DEALS:-
BenQ GL955A 18.5" Widescreen LED Monitor - Black @ £65.99 inc VAT
Whether you’re catching up on the latest show on the Internet or viewing documents, the BenQ GL955A LED monitor is the perfect choice for you! Featuring a dynamic contrast ratio of 12M:1, response time of 5ms, and BenQ’s exclusive Senseye® Technology, this 18.5”W 16:9 LED monitor delivers you the visual enjoyment with best value.
LED backlighting offers significant advantages over the CCFL technology used in older LED monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
The GL955A comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
Features
- Screen Size: 18.5" Wide
- Resolution (max.): 1366 x 768
- Pixel Pitch: 0.3 mm
- Brightness: 200 cd/m²
- Contrast Ratio: 600:1
- Dynamic Contrast Ratio: 12,000,000:1
- Response Time: (tr/tf) 5ms
- Display Area: 409.8 x 230.4 mm
- Display Color: 16.7 million
- Viewing Angle: (L/R;U/D) (CR>=10) 90 / 65
- Terminals: D-sub
- Horizontal Frequency (Max) KHz 30 ~ 83
- Vertical Frequency (Max)Hz 50 ~ 76
- Video Bandwidth (MHz) 110
- Colour Temperature Reddish / Normal / Bluish / User mode
- Power Consumption 23W (on mode)
- Auto Switching Power Supply Built-in
- Power Saving Mode <1W
- Senseye+Photo Technology
- HDCP Support: NO
- Adjustments Tilt: -5 / 20 (down / up)
- Dimensions (HxWxD): 345.8 x 444.4 x 165 mm
- with wall mount: 278.8 x 444.4 x 62.1 mm
- Weight: Net 2.8 kg / Gross 4.3 kg
- Accessories (Standard): VGA cable / Power cable
- VESA: Yes (100x100mm)
- Warranty: 2yrs
Was [£79.99] Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Asus VE228HR 22" Widescreen LED Multimedia Monitor - Black @ £109.99 inc VAT
Full HD 1080p Visual Enjoyment Together with HDMI Interface. Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 21.5"(54.6cm) Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.248mm
- Brightness(Max) : 250 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 800000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Video Feature SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 30 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 512.84x385.96x201mm
- Box Dimension(WxHxD): 576x468x148mm
- Weight Net Weight (Esti.): 4.1 kg
- Gross Weight (Esti.): 6.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval Energy Star 5.0, CEL, UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, WEEE, Windows Vista & Windows 7 WHQL
Was [£139.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
BenQ G2250 22" Widescreen LCD Monitor - Black @ £85.99 inc VAT
Enjoy the spacious view while reviewing work documents or catching up on the latest show online! Featuring a 21.5"W 16:9 LCD display, 50000:1 dynamic contrast ratio and 5ms response time, the BenQ G2250 is built to deliver the best picture quality for work or play!
An enjoyable addition to your everyday home or work life, the G2250 gives you crisp and accurate viewing at all times .
The G2250 comes with a dynamic contrast ratio of 50000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
The BenQ G2250 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing.
Experience the truest colors of the world with the BenQ Senseye® Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye® 3 delivers only the best viewing quality in each of its six pre-set viewing modes –Standard, Movie, Game, Photo, sRGB, and Eco – with the Eco Mode especially designed to save power and money.
Features:-
- Screen Size 21.5"W
- Resolution (max.) 1920 x 1080
- Pixel Pitch 0.248 mm
- Brightness 300 cd/m2
- Contrast Ratio 1000:1
- DCR: 50000:1
- Response Time (tr/tf) 5 ms
- Display Color 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10) 170 / 160
- Terminals D-sub / DVI-D
- Power Consumption 27W (max)
- Features Senseye® Human Vision Technology (plus Senseye 3)
- HDCP Support
- OSD Language: 17 languages
- Windows 7® compatible
- K locker: yes
- Adjustments Tilt (down / up) -5 / 15
- Dimensions (HxWxD) 399.9 x 524.69 x 173.9 mm
- Weight Net weight: 3.7 kg.
- Gross weight: 5.3 kg.
- Accessories (Standard) VGA
- Product Colour Glossy Black
- Vista Certification Premium
- VESA Wall Mounting 100 x 100 mm
- 2yr Warranty
Was [£99.95] Inc. VAT
Only £85.99 inc VAT.
ORDER NOW
BenQ GW2255 22" Widescreen LED Monitor - Black @ £89.99 inc VAT
Built to bring you the ultimate personal visual entertainment, the BenQ GW2255 is certainly one of a kind! Featuring the 3000:1 native contrast, 20M:1 dynamic contrast ratio, and true 8-bit panel performance with deep blacks and minimized light leakage, this VA LED monitor refreshes your view with truly fantastic colors and details.
After launching the world's first VA LED monitor, BenQ - the world's leading LED monitor brand - is now taking the lead to introduce VA LED to our home & offcie offering: GW Series! Built with the dream combination of LED with VA panel, GW Series is bound to bring a whole new visual experience and enjoyment to you with truly authentic colors, deeper blacks, higher contrast and sharper details.
The GW2255 comes with a native contrast ratio of 3000:1 and dynamic contrast ratio of 20M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
Specification:-
- Screen Size: 21.5"W, VA LED
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.248 mm
- Brightness: 250 cd/m2
- Contrast Ratio: 3000:1
- DCR: 20M:1
- Response Time: 6ms GTG
- Display Area: 476.64 x 268.11 mm
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: D-sub / DVI-D / Headphone jack / Line in
- VA LED Technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Advanced Motion Accelerator (AMA)
- HDCP Support
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 2yr
Was [£113.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Samsung S22C300BS 22" Widescreen LED Monitor - Rose Black @ £89.99 inc VAT
Experience amazing new levels of colour, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SC300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5000000:1 contrast ratio, the highest level currently available, the SC300 monitor ensures that blacks are at their absolute darkest and (with pristine whites) colours are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colours and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio – and enjoy your multimedia content with the professionalism it deserves.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
- 21.5" (16:9)
- LED Technology
- Resolution: 1920x1080 (True HD)
- Contrast Ratio: Dynamic: Mega DCR (Static: 1000:1)
- Brightness: 250cd/m2
- Response Time: 5ms
- Colour Support: 16.7M
- Input Connection: 1x Analogue & 1x DVI
- Stand type: Simple, tilt function only
- Wall Mount: No
- Set Dimension with Stand (WxHxD): 512 X 385 X 197 mm
- Set Dimension without Stand (WxHxD): 512 X 311 X 53 mm
- Set Weight with Stand: 3.0 kg
- Cables: D-Sub Cable included
- Apple & PC compatible
- 3yr Warranty
Was [£109.99] Inc. VAT
ORDER NOW
AOC G2460PQU 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal @ £229.99 inc VAT
This display will make any gaming enthusiast´s heart beat faster: the stylish g2460Pqu will impress you with crystal-clear pictures. Enjoy fast-paced action sequences from the latest games or movies – crisp and blur-free due to an ultra-fast response time of just one millisecond and a refresh rate of 144 Hz. The strong typical contrast (1000:1) and high brightness (350 cd/m²) provide brilliant images. This gamers´ dream-come-true sports numerous connectivity options, such as D-Sub, DVI Dual Link, HDMI, DisplayPort and an integrated USB hub. These enable you to comfortably plug in several devices at the same time and display hi-res content on the large 61 cm (24") screen. Also on board: an integrated USB hub with 4 ports, including a fast-charge USB port for mobile devices. In addition, the Full HD display is equipped with LED backlights, making it particularly economical despite its great performance.
Product Review
- Won Kitguru "Worth Buying" Award
- Full Review Here: http://www.kitguru.net/peripherals/monitors/zardon/aoc-g2460pqu-144hz-24-inch-monitor-review/
Specification:-
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: Analogue, DVI-D, HDMI & DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Warranty: 3yr
Was [£239.99] Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
Asus VE247H 24" Widescreen LED Multimedia Monitor - Black @ £143.99 inc VAT
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 23.6"(59.9cm) 16:9 Wide Screen
- Pixel Pitch : 0.272mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Response Time : 2ms (Gray to Gray)
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- HDCP support
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI 1.3,D-Sub,DVI-D
- Power Consumption Power Consumption < 35 W
- Tilt : +20°~-5°
- Dimensions Phys.Dimension(WxHxD): 569.4 x409.7x201mm
- Box Dimension(WxHxD): 638x 480 x175mm
- Weight Net Weight (Esti.): 4.4 kg
- Gross Weight (Esti.): 7.1 kg
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
Was [£149.99] Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Asus VN247H 24"Widescreen Super Narrow Bezel LED Monitor - Black @ £149.99 inc VAT
The ASUS VN series features compact dimensions- this 23.6” display has a super narrow bezel less than 1cm thick, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN247H is also VESA wall mount compatible, and has the capabilities to be a stunning multi-screen solution.
VN247H leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and rich connectivity including dual HDMI and D-sub inputs. An Ultra-fast 1ms gray-to-gray response time and trace free technology deliver realistic moving visuals and a blur-free multimedia experience. With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 250cd/m² brightness, the VN247H enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
VN247H comes with rich connectivity including Dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey. ASUS includes its exclusive QuickFit Virtual Scale feature with the VN247H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
Features:-
- Ideal for a multi-screen solution with a super narrow frame
- Best for work and play with Full HD 1080p visual quality and rich connectivity including dual HDMI and D-sub inputs
- Ultra-fast 1ms (gray-to-gray) response time for amazingly blur-free multimedia experience
Specification:-
- Panel Size: Wide Screen 23.6"(59.9cm) 16:9
- True Resolution: 1920x1080
- Full HD 1080P: Yes (support 1080i/p by 1:1)
- Pixel Pitch: 0.272mm
- Brightness(Max): 250cd/m
- ASUS Smart Contrast Ratio (ASCR): 80000000:1
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 1ms SUPER-FAST Response time
- Display Colors: 16.7M
- Signal Input: 2x HDMI & 1x D-Sub (DVI-D Supported via HDMI-to-DVI cable)
- Stereo Speakers: 2W x2 Stereo RMS
- VESA: 100x100mm
- Kensington Lock: Yes
- Phys. Dimension with Stand(WxHxD): 548.6x394.9x194.2mm
- Weight: 3.7kg
- Warranty: 3yr
Was [£169.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
BenQ XL2411T Rev2.0 24" TRUE 144Hz Flicker FREE 3D Vision 2.0 Widescreen LED Monitor - Black @ £241.99 inc VAT
The XL2411T demonstrates BenQ's true belief that "gaming is in the details" It has been co-developed with Counter-Strike pro gaming legends to bring you a gaming monitor like no other - from the attentive designs to the exceptional functions. With the precision and speed you would expect from a high-performance gaming monitor, you can now have a vantage point over your opponents in all your game play.
The task of conceptualizing the XL2411T as the ultimate gaming monitor involved a unique collaboration with prominent pro gamers: Tommy "Potti" Ingemarsson, Emil "HeatoN" Christensen, Abdisamad "SpawN" Mohamed, Michael "ahl" Korduner and Christer "fisker" Eriksson. These five names alone are synonymous when it comes to legendary Counter-Strike players. Their accumulated wealth of knowledge and skills helped BenQ develop a monitor that adapts to the needs of gamers to improve their chances of winning.
Poor visibility in dark scenes can cost even the most skilful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
The XL2411T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you're able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. Now switching seamlessly between the presets is as easy as 1-2-3.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between different screen sizes, from 17" (4:3), 19" (4:3), 19"W (16:9), 21.5"W (16:9), 22"W (16:10), 23"W (16:9) to 24"W (16:9), using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
The preset FPS mode tailored by HeatoN and SpawN gives you the optimal brightness, contrast, sharpness and color tint in FPS games so you can spot your opponents and track their every move, even in indistinct situations. There are two variations to this special mode this year: the FPS1 mode is designed for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
With a refresh rate of 120Hz, there's never a lag and every in-game details will be smoothly rendered. Drawing on hyper-speed video processing technology, the XL2411T gives you on-screen action and captivating realism.
Fast response time of 2ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
The newly designed OSD enables you to conveniently change your settings in an intuitive horizontal slide out menu display. This simplistic design makes it easier to navigate between options and settings.
The secret is out. Download special gaming presets used by HeatoN and SpawN so you can see what the pros see. Each mode is fine tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. Users can install these exclusive presets and leverage them to their advantage. More presets from legendary gamers will be released in the future so you can always stay on top of your game.
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy.
Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology so you can experience gaming and entertainment like never before with total realism and intensive graphic display
Features:-
- Product Color: Black
- Screen Size: 24"W LED-backlight
- Pixel Pitch: 0.276 mm
- Contrast Ratio: 1,000:1 / DCR:12,000,000:1
- Response Time: 2 ms GtG
- Viewing Angle (L/R;U/D) (CR>=10): 170 / 160
- Color Gamut: 72%
- Terminals: D-sub / DVI-DL (Dual Link) / HDMI x 1 / Headphone Jack
- Color Temperature: Reddish / Normal / Bluish / User mode
- Features: Black eQualizer, Smart Scaling, FPS Mode, RTS Mode, Game Mode Loader, NVIDIA® 3D Vision™ 2 ready, Senseye 3, AMA
- HDCP
- K-Locker mount
- Height adjustment: 130mm
- Tilt (down / up): -5 / 20
- Swivel (left / right): -45 / 45
- Pivot: 90°
- 571.4 x 516.9 x 149.9 mm
- Gross weight: 6.1 kg
- VESA Wall Mounting (mm): 100 x 100 mm <
- 2yr On-Site Warranty
Was [£269.99] Inc. VAT
Only £241.99 inc VAT.
ORDER NOW
BenQ XL2420T rev2.0 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red /w Flicker FREE Technology @ £299.99 inc VAT
This revision 2.0 model is the same as the XL2420TE which is sold only in the USA, this version 2.0 is identical to that model found in the USA featuring Flicker FREE technology and 144Hz.
The XL2420T demonstrates BenQ’s true belief that "gaming is in the details" It has been co-developed with Counter-Strike pro gaming legends to bring you a gaming monitor like no other – from the attentive designs to the exceptional functions. With the precision and speed you would expect from a high-performance gaming monitor, you can now have a vantage point over your opponents in all your game play.
The task of conceptualizing the XL2420T as the ultimate gaming monitor involved a unique collaboration with prominent pro gamers: Tommy “Potti” Ingemarsson, Emil “HeatoN” Christensen, Abdisamad “SpawN” Mohamed, Michael “ahl” Korduner and Christer “fisker” Eriksson. These five names alone are synonymous when it comes to legendary Counter-Strike players. Their accumulated wealth of knowledge and skills helped BenQ develop a monitor that adapts to the needs of gamers to improve their chances of winning.
Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
The XL2420T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you’re able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. Now switching seamlessly between the presets is as easy as 1-2-3.
With a refresh rate of 144Hz, there’s never a lag and every in-game details will be smoothly rendered. Drawing on hyper-speed video processing technology, the XL2420T gives you on-screen action and captivating realism.
Fast response time of 2ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don’t leave it in the hands of slow display.
Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology so you can experience gaming and entertainment like never before with total realism and intensive graphic display. Furthermore, the XL2420T supports D-Sub, HDMI, DVI-DL and DP inputs for console gaming action.
Features:-
- rev2 with Flicker FREE technology
- 144Hz Version
- Product Color: Black-Red
- Color Gamut: 72%
- Terminals: D-sub / DVI-DL (Dual Link) / HDMI x 2 / DP 1.2 / Headphone Jack
- USB Hub: Donwstream x3; Upstream x1
- HDCP
- K-Locker mount
- Pivot: 90°
Was [£319.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Iiyama Prolite E2481HS-B1 24" Widescreen LED Super Slim Bezel Monitor - Black @ £131.99 inc VAT
The ProLite E2481HS is a 24’’ Full HD 1920 x 1080p LED-backlit monitor with super slim (7 mm) bezel. It features 2ms response time and >5 000 000 : 1 Advanced Contrast Ratio assuring clear and vibrant picture quality. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The monitor is Energy Star and TCO Certified. A reliable solution for all kind of work environments where best performance is desired.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. VESA mount compliance means you can easily mount your monitor to a wall.
Specification:-
- Diagonal: 23.6"
- Panel: TN, LED-Backlit
- Display area h x w: 293.22 x 521.28 mm; 11.5" x 20.5"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 250 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 170°; right/left: 89°/ 89°; up/down: 85°/ 85°
- Display colour: 16.7 million
- Pixel pitch h x v: 0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 56 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- Input connections: VGA, DVI-D & HDMI
- Speakers: 2 x 2 W (Stereo)
- Anti-theft-device: Kensington-lock™ prepared
- Certificates: CE, CU, TUV-GS, TCO
- Tilt angle: 21° up; 4° down
- VESA mounting: 100 x 100 mm
- Warranty: 3yr
Only £131.99 inc VAT.
ORDER NOW
Packard Bell Viseo 243D 24" Widescreen LED Monitor - Black @ £99.95 inc VAT
A great monitor from Packard Bell housed in a traditional high quality monitor exclosure with black finish for a professional look. Great image quality with pixel sharp text from DVI connectivity. Also ideal for gaming with quick 5ms response time.
Features
- Screen Size: 24" Widescreen
- Contrast Ratio: 1,000,000:1
- Brightness: 200cd/m²
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Colors: 16.7 M
- HDCP compatible: Yes
- Warranty: 3 Years On-Site
Only £99.95 inc VAT.
ORDER NOW
Asus VG278HE 27" TRUE 144Hz 3D Widescreen LED Monitor - Black @ £371.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278HE. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology*, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278HE is able to double per second to deliver ultra-smooth motion scenes in intense actions, which is over twice faster than generic LCD monitors, delivering ultra-smooth 2D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey.
VG278HE comes with rich connectivity including HDMI 1.4, Dual-link DVI-D, D-Sub. Users could simultaneously connect VG278HE to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players, audio devices and set-top boxes for limitless entertainment with its built-in stereo speakers
Features:-
- Ultra smooth action with 144Hz rapid refresh rate and 2ms (GTG) tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- A comfortable viewing with ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- VG278HE supports NVIDIA 3D Vision 2 through connection of Dual-link DVI.
- Suggest purchasing the additional NVIDIA 3D Vision 2 Kit for immersive 3D enjoyment, also available from OcUK!
Specification:-
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- Pixel Pitch: 0.311mm
- Brightness(Max): 300 cd/?
- ASUS Smart Contrast Ratio (ASCR): 50000000:1
- Response Time: 2ms (Gray to Gray)
- Trace Free Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard Mode/Night View Mode/Game Mode)
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Power Consumption(Typical): <65W
- Power Saving Mode: <1W
- Power Off Mode: <1W
- Voltage: 100-240V, 50/60Hz
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- Kensington lock
- Phys.Dimension with Stand(WxHxD):643x437.8x249.7mm
- Phys. Dimension without Stand(WxHxD):643x385.6x59.5mm(For VESA Wall Mount)
- Box Dimension(WxHxD):732x560x176mm
- Net Weight (Esti.): 8kg
- Gross Weight (Esti.): 10kg
- Warranty: 3yr
Was [£399.95] Inc. VAT
Only £371.99 inc VAT.
ORDER NOW
Asus VG278HR 27" TRUE 144Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £439.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 144 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 144Hz refresh rate and 2ms tracer-free
- Ergonomic design for swivel, tilt angle, and height adjustment
- Full HD 1080P : Yes
- Pixel Pitch : 0.311mm
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- HDCP support
- Tilt : +15°~-5°
- Swivel : Yes
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was [£479.99] Inc. VAT
Only £439.99 inc VAT.
ORDER NOW
BenQ EW2740L 27" Widescreen LED Professional Monitor - Black @ £215.99 inc VAT
With a sophisticated all-around slim design, the latest MHL connection and BenQ’s state-of-the-art visual optimization technologies, the all-new EW40 Series take your multimedia entertainment to a new level of fun and ease. Enjoy a cinema-class picture in the comfort of your own personal space for home entertainment or office work.
Connect your smart device to the new EW40 Series and indulge in the premium picture quality that is has to offer. The MHL connection ensures flawless streaming from any MHL-equipped smart device, allowing you to enlarge and optimize any content displayed on your smart device effortlessly. With this feature, you can browse websites, watch videos, play games and even go over various documents on a full 24” or 27” screen – without having to turn on your computer at all.
Enabled by BenQ’s exclusive color engine technology, the Cinema Mode automatically processes and fine-tunes video contents to perfection, so that a truly dynamic cinema experience is what you’ll get. To give you an optimal online video watching experience, the EW40 Series simulates high-resolution images by boosting the pixel density of the original video source with the Super Resolution image enhancement feature. Smart Focus allows you to pinpoint a window or area on the screen and make that the focal point. By concealing the rest of the visual content, you’re able to focus on exactly what you aim to enjoy.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but can certainly feel them. Free your eyes from flickers by switching to Flicker-free Monitors and let your eyes do less work.
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ’s unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light Modes from OSD hot key (Multimedia – 30% reduction, Web-surfing – 50% reduction, Office – 60% reduction, Reading – 70% reduction), and reward your eyes without having to lose the visual enjoyment.
Specification:-
- Screen Size: 27”
- Aspect Ratio: 16:9
- Resolution (max.): 1920x1080
- Pixel Pitch (mm): 0.311
- Brightness ( typ.): 300 cd/m2
- Native Contrast ( typ. ): 3000:1
- DCR (Dynamic Contrast Ratio) (typ.): 20M:1
- Panel Type: VA
- Viewing Angle (L/R;U/D) (CR>=10): 178/178
- Response Time(Tr+Tf) typ: 4ms (GtG)
- Display Colors: 16.7million
- Inputs: D-sub + HDMx2
- Dimensions(HxWxD mm): 451 X 623 X 191
- HDCP: Yes
- 2yr Warranty
Only £215.99 inc VAT.
ORDER NOW
BenQ GW2760 27" Widescreen LED Flicker-Free Multimedia Slim Bezel Monitor - Black @ £155.99 inc VAT
Built to bring you the ultimate personal visual entertainment, the BenQ GW2760 is certainly one of a kind! Featuring the speakers, ultra-high 3000:1 native contrast, 20M:1 dynamic contrast ratio, and true 8-bit panel performance with deep blacks and minimized light leakage, this VA LED monitor refreshes your view with truly fantastic colours and details.
Key Features:-
- VA LED Leads the Way
- An integral part of your home and workplace décor
- Flicker-free Backlight for Visual Pleasure
- Reading Mode for an Optimized Reading Experience
- Full HD 1080p 16:9 Visual Perfection
- Senseye® 3 Visual Solution to Your Everyday Viewing Needs
Specifications:-
- Screen Size: 27"
- Screen Type: LCD
- Backlight: LED
- Screen Features: Full HD
- Response Time: 4ms (GTG)
- Dynamic Contrast Ratio: 20,000,000:1
- Brightness: 300 cd/m²
- Max. Resolution: 1920 x 1080
- Horizontal Viewing Angle: 178°
- Vertical Viewing Angle: 178°
- Tilt Angle: -5°/20°
- VGA Port(s): 1
- DVI-D Port(s): 1
- Line In Jack(s): 1
- Speaker(s): Integrated
- Product Width: 641mm
- Product Width (without stand): 641mm
- Product Height: 490mm
- Product Height (without stand): 488.08mm
- Product Length: 214.65mm
- Product Length (without stand): 56.95mm
- Input Power Source: Power Lead
- Normal Power Consumption: 27W
- Stand-by Power Consumption: 0.3W
- Wall Mount: VESA 100mm x 100mm
- Energy Star: 5.0
- Warranty: 2yr
Was [£179.99] Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
Benq XL2720T 27" TRUE 120Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red @ £329.99 inc VAT
The XL2720T demonstrates BenQ's true belief that "gaming is in the details" It has been co-developed with Counter-Strike pro gaming legends to bring you a gaming. Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
The XL2720T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you're able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. Now switching seamlessly between the presets is as easy as 1-2-3. conveniently change your settings in an intuitive horizontal slide out menu display. This simplistic design makes it easier to navigate between options and settings.
The secret is out. Download special gaming presets used by the legendary Counter-Strike players so you can see what the pros see. Each mode is fine-tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. They can also be saved on your S Switch for quick access and game play. More presets from legendary gamers will be released in the future so you can always stay on top of your game.
Meet your secret winning strategy. The FPS Mode was co-developed with gaming legends to let you tap into the fundamental insights of pro gamers and view the game how a gaming legend would see it. This out-of-the-box preset automatically adjusts your monitor calibrations to provide you with optimal brightness, contrast, sharpness and color tint. Being able to spot your enemies and track their move carefully in every situation put you at an advantage over your opponents.There are two variations to this special mode: the FPS1 mode is designed to configure and optimize the display for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source as recommended by BenQ. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between different screen sizes, from 17" (4:3), 19" (4:3), 19"W (16:10), 21.5"W (16:9), 22"W (16:10), 23"W (16:9), 23.6"W (16:10), 24"W (16:9) to 27"W(16:9), using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
With a refresh rate of 120Hz, there's never a lag and every in-game details will be smoothly rendered. Drawing on hyper-speed video processing technology, the XL2720T gives you on-screen action and captivating realism. Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display. Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology so you can experience gaming and entertainment like never before with total realism and intensive graphic display. Furthermore, the XL2720T supports D-Sub, HDMI, DVI-DL and DP inputs for console gaming action.
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy. BenQ professional gaming monitors are not only the official global Tournament monitor of top notch league and tournaments, but also unrivaled victor of world renowned design awards. In addition, BenQ professional gaming monitors are used by prominent gamers to perfect their gameplay.
Specification:-
- Back Light Unit: LED
- LCD Size: 27"W 120HZ
- Resolution (max.): 1920×1080
- Brightness (typ.): 300 cd/?
- Contrast (typ.): 1000:1
- DCR (typ.) (Dynamic Contrast Ratio): 12M:1
- Panel Type: TN
- Viewing Angle: (L/R;U/D) (CR>=10): 170 / 160
- Response Time (Tr+Tf) typ: 5ms, 1ms (GtG)
- Display Colors: 16.7 million
- Color Gamut: 72%
- Input Connector: D-sub/DVI-DL/HDMI/DP
- USB Hub: Donwstream x 3, Upstream x 1
- VESA Wall Mounting: 100X100 mm
- Swivel (left/right): 45/45
- Tilt (down/up): -5/20
- High Adjustment (mm): 140 mm
- K-Locker: Yes
- CTN Dimensions (HxWxD mm): 486 X 711 X 245
- Dimensions (HxWxD mm): 548 X 642 X 273
- Dimensions with Wall Mount (HxWxD mm): 485 X 642 X 269
- Net Weight (kg): 7.5
- Gross Weight (kg): 10.2
- Warranty: 2yr
Was [£359.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Dell UltraSharp U2713HM 27" Widescreen LED Monitor - Midnight Grey @ £429.95 inc VAT
Cinema-like clarity shines on the expansive 27" DellTM UltraSharp U2713HM monitor. Comfort settings and connectivity options help keep you productive. WQHD resolution and accurate colors out of the box: Superb clarity with 2560 x 1440 resolution and over 3.6 million pixels. Features a color gamut of more than 99-percent sRGB.
Excellent comfort and usability: Full adjustability including swivel, tilt, height adjustability and pivot which lets you easily switch to portrait mode. Eco-friendly design: Compliant with the latest environmental standards and made using environmentally conscious materials
2560x1440 WQHD resolution: Over 3.6 million pixels provide amazing clarity on a spacious 27" LED-backlit display. Easily adjust screen brightness to suit your environment. Accurate color right out of the box: Carefully color calibrated at the factory, the U2713HM monitor features more than 99-percent sRGB color space for impressive color from the moment you set it up. Wide-angle viewing: Uncompromised color consistency across an ultra-wide viewing angle of 178°/178° gives you broad viewing flexibility and lets you collaborate easily.
Full adjustability: Work comfortably and view images from a variety of positions with swivel and tilt. Easily switch to portrait mode with pivot. Set your U2713HM to the optimum height with a height-adjustability range of 115mm. Latest connectivity options: Seamlessly connect your monitor to your desktop, laptop and peripherals such as digital cameras and Blu-ray or DVD players. Digital and analog connections include four USB 3.0 ports, DisplayPort 1.2, DVI (HDCP) and HDMI. Stay productive with Dell Display Manager: This one-stop software tool lets you quickly access applications such as Auto Mode, Easy Arrange and PowerNap. Use Auto Mode to adjust or auto-assign preset modes to specific applications. Use Easy Arrange to neatly tile your applications, arranging them in your preferred layout
Meets latest environmental standards: The U2713HM monitor meets EPEAT® Gold and TCO Certified Displays standards, is ENERGY STAR® qualified and CECP compliant. Made with responsible materials: This monitor is made with arsenic-free glass, a mercury-free panel, uses 25-percent post-consumer recycled plastics in its chassis and BFR/PVC-free laminates in its circuit boards. The U2713HM also ships with environmentally responsible packaging. Helps save resources: Enable PowerNap mode to reduce power consumption by dimming the monitor to minimum brightness or by putting it into sleep mode.
Features:-
- LED Backlit
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 2,000,000:1
- Brightness: 350cd/m²
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI, 1x DisplayPort,
- 5-Port USB3.0 Hub
- VESA Compliant
- Dimensions: 639.3mm (25.17'') x 200.3mm (7.89'') x 424.3mm ~ 538.9mm (21.22'' ~ 16.70'')
- Weight: 10.20kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Was [£469.99] Inc. VAT
Only £429.95 inc VAT.
ORDER NOW
Dell UltraSharp U2913WM 29" Super-Widescreen LED Monitor - Midnight Grey @ £371.99 inc VAT
Navigate multiple applications at once and multitask like never before. A vast, 29" panoramic display with a 21:9 aspect ratio and 2560 x 1080 Wide Full-HD offers the screen space of side-by-side monitors without a distracting bezel in between. Plus, with a 178°/178° (typical) ultra-wide viewing angle, you can enjoy an excellent view from almost any position.
Experience remarkably precise and accurate color made possible by over 99 percent sRGB at a delta-E of less than 5, offering broad color variation. Plus, the U2913WM comes factory color-calibrated, so you can enjoy outstanding color accuracy right out of the box.
Make it work for you, with extensive connectivity such as DisplayPort 1.2, USB 3.02, Mini DisplayPort, DVI and HDMI, plus highly adjustable tilt and swivel positioning, a 130mm height adjustability range and a VESA-compatible wall mounting option (mounting kit sold separately).
Synchronize your applications and improve your visual experience. Dell Display Manager offers a variety of features that can optimize your media presentation and maximize your monitor’s real estate, such as Easy Arrange and Auto Mode.
Automatically optimize your video settings with the Smart Video Enhance3 feature, optimizing colors and sharpness for the best possible presentation. Choose Movie mode for recommended settings, or choose Advanced mode to manually adjust contrast, sharpness, color saturation and hue however you like.
Stay energy-efficient with PowerNap and dynamic dimming features that automatically help regulate power usage. Plus, the U2913WM features an eco-conscious design with arsenic-free glass, mercury-free LED and BFR/PVC-free laminates in the chassis. The U2913WM is EPEAT® Gold and ENERGY STAR® qualified and comes packed in eco-conscious recyclable packaging.
Specification:-
- Panel: 29-inch (73.02cm( (diagonal) VIS with LED backlights
- 21:9 aspect ratio
- LED Technology
- Brightness: 300cd/m
- Response: 8ms
- Resolution: Wide Full-HD 2560 x 1080 at 60 Hz (Max)
- Viewing Angles: 178°/178° ultra-wide viewing angle
- In-plane switching technology
- Color calibration factory report
- More than 99% sRGB (deltaE < 5)
- Input Connections: DisplayPort 1.2 / mini-DisplayPort, DP-out, HDMI, DVI-D (HDCP), VGA
- USB3.0 Hub (4 downstream / 1 upstream)
- Tilt, swivel and height adjustable (130mm)
- Option to wall mount in landscape and portrait mode (VESA 100mm x 100mm)
- Arsenic-free glass and mercury-free LED panel
- Dell Display Manager - Auto mode, PowerNap, Easy Arrange, Smart Video Enhance
- ENERGY STAR®, EPEAT Gold, TCO Certified Displays, ErP Standards compliant
- 3yr Onsite-Warranty
ORDER NOW
Dell UltraSharp U3014 30" Widescreen LED Monitor - Midnight Grey @ £899.99 inc VAT
Users will experience outstanding color accuracy, precision and performance with the Dell UltraSharp U3014 30-inch monitor with PremierColor. The U3014 is Dell’s flagship high performance monitor with a 16:10 aspect ratio, suitable for the fine level of detail required for color-critical work such as CAD/CAM, graphic design, desktop publishing, gaming or media creation. In addition, users will experience stunning high-definition details and the ability to view more onscreen content with 2560 x 1600 resolution. More than just a high performance monitor, the U3014 offers flexible viewing options, versatile digital connectivity and is designed for exceptional efficiency with an eco-design that meets the latest environmental standards like EPEAT®, ENERGY STAR® and TCO Certified Displays.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- Light AG coating
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 10-Bit Colour
- 1000:1 Contrast Ratio
- 6ms Response Time (6ms Grey-TO-Grey)
- 350 cd/m2 Brightness
- DVI-D Input with HDCP support
- HDMI Input
- Display Port Input
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 3.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Smart Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
- Product Review @ TFT Central: http://www.tftcentral.co.uk/reviews/dell_u3014.htm
Was [£999.95] Inc. VAT
Only £899.99 inc VAT.
ORDER NOW
Iiyama Prolite E2773HS-GB1 27" Widescreen LED 1MS Monitor - Black @ £179.99 inc VAT
The LED-backlit ProLite E2773HDS 27” LCD Display features a stunning 1 ms Response Time and a High Definition 1920 x 1080 Resolution. The 5 000,000:1 Advanced Contrast Ratio and 300 cd/m² brightness offer the user clear and vivid images, and the HDMI, DVI and D-Sub connections ensure compatibility across a range of devices including games consoles and work stations. The display is Windows® 7 Compatible and Energy Star® 5.0 qualified.
Features:
- LED Backlit
- Full HD
- ACR Capeablity
- Inbuilt Speakers
- HDMI Input
- Overdrive Feature
- VESA Mountable
- Compatible with Xbox 360 & PS3
Technical Specifications:
- Screen Size: 27" Widescreen
- Contrast Ratio: 5 000 000 : 1
- Brightness: 300cd/m²
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 5.3kg
Was [£209.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Samsung S27B970D 27" Widescreen Ultra Thin LED Professional PLS Monitor - Black @ £509.99 inc VAT
The trailblazing big-screen Samsung Series 9 introduces an exceptional generation of monitors, with superior visual advances from the industry’s five-year global market leader. Remarkable resolution and vivid brightness fill the screen edge to edge with the limitless colors of nature, delivering unrivaled picture quality. Set on an elegant base with a sleek frame, the monitor renders intensely rich colors and astonishing detail, even at wide angles. Quite simply, the Series 9 outshines other screens.
Samsung’s exclusive technology automatically calibrates brilliant true-life color, taking the challenge out of choosing a monitor with premium picture quality. The Series 9 relives your memorable moments on the monitor in the vivid detail you remember.
Answering the need for higher resolution and precise detail editing, the Series 9 Monitor showcases extraordinary picture quality without losing any color or perspective, even from ultra-wide angles. Its WQHD technology enables the images to remain ultra-crisp with resolution that’s four times
higher than older conventional HD monitors.
With its slim and gleaming silhouette, the Samsung Series 9 showcases shimmering images that seem to display in mid-air. The crystal clear tempered glass screen enhances both the vivid images and the streamlined design. Innovative LED Touch UI delivers emotionally intimate engagement and satisfying results. Ports are artfully concealed in the back to highlight the stylish brushed aluminum hairline (HL) finish. Simply elegant, the Samsung Series 9 Monitor represents world-class innovation.
Defined by distinctive forward-looking and consumer-friendly design, the Samsung Series 9 Monitor is made for ongoing value. The Series 9 internal performance is as advanced as its striking exterior. Along with sensational good locks, you’ll discover intuitive and exacting technology as well as an ergonomic Height Adjustment Stand (HAS) and tilt for comfortably customized viewing. The Samsung Series 9 offers unequaled simplicity.
Engineered to deliver unparalleled picture quality and consistently accurate all-natural color, the Samsung Series 9 works to make that experience as seamless as possible. Enjoy content from MHL-enabled smartphones and tablets with the benefit of richly displayed images and compelling audio. You also can simultaneously browse on smartphones and even charge devices.
The Samsung Series 9 premium monitor delivers the best in picture quality, style and connectivity. Its exclusive color technology renders vivid content, video, photos and more. This monitor sets the new standard for sophisticated and approachable design, appropriate for any décor. Multimedia connections are easy and seamless for all devices. The Samsung Series 9 will surpass your every expectation.
Specification:-
- Screen finish: Glossy (Reflective)
- Screen Size: 27" / 68cm (16:9)
- Type: PLS LED
- Brightness: 285cd/m (High Bright Mode), 220cd/m (Standard Mode)
- Contrast Ratio: Mega DCR (Static 1000:1)
- Resolution: 2560x1440 (Wide Quad-HD)
- Viewing Angle: 178 / 178
- H/W Calibration Engine
- Connections: Dual Link DVI, DisplayPort, HDMI 1.4
- 2x7W Speakers
- USB Hub
- Dimensions: 645 x 467 x 247mm
- Warranty: 3yr
- Product Review: http://www.expertreviews.co.uk/monitors/1293385/samsung-series-9-s27b970d
- Product Videos: http://www.youtube.com/samsungmonitorglobal; http://www.youtube.com/watch?v=Pn3gsyEKzKQ&noredirect=1
Was [£599.99] Inc. VAT
Only £509.99 inc VAT.
ORDER NOW
Samsung S27B971D 27" Matte Widescreen Ultra Thin LED Professional PLS Monitor - Black @ £499.99 inc VAT
Specification:-
- Screen finish: Matte/Dull (Non-Reflective)
- Type: PLS LED
- 2x7W Speakers
- USB Hub
- Warranty: 3yr
Only £499.99 inc VAT.
ORDER NOW
This weekend is the time to buy a monitor for sure!!!!
Features
- Terminals: D-sub
- HDCP Support: NO
- Warranty: 2yrs
ORDER NOW
Features:-
- HDCP support
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- Tilt : +20°~-5°
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
ORDER NOW
Features:-
- DCR: 50000:1
- HDCP Support
- K locker: yes
- 2yr Warranty
ORDER NOW
Specification:-
- DCR: 20M:1
- VA LED Technology
- HDCP Support
- Warranty: 2yr
ORDER NOW
- 21.5" (16:9)
- LED Technology
- Wall Mount: No
- 3yr Warranty
ORDER NOW
Product Review
Specification:-
- Monitor Size: 24"
- Colors: 16.7 M
- Warranty: 3yr
ORDER NOW
Features:-
- HDCP support
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- Tilt : +20°~-5°
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
ORDER NOW
Features:-
Specification:-
- VESA: 100x100mm
- Weight: 3.7kg
- Warranty: 3yr
ORDER NOW
Features:-
- Color Gamut: 72%
- HDCP
- K-Locker mount
- Pivot: 90°
ORDER NOW
Features:-
- 144Hz Version
- Color Gamut: 72%
- HDCP
- K-Locker mount
- Pivot: 90°
ORDER NOW
Specification:-
- Diagonal: 23.6"
- Warranty: 3yr
ORDER NOW
Features
- Colors: 16.7 M
ORDER NOW
Features:-
Specification:-
- HDCP support
- Tilt : +15°~-5°
- Swivel : Yes
- Kensington lock
- Warranty: 3yr
ORDER NOW
Features:-
- HDCP support
- Tilt : +15°~-5°
- Swivel : Yes
- Kensington lock
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- 3yr Warranty
ORDER NOW
Specification:-
- Screen Size: 27”
- Panel Type: VA
- HDCP: Yes
- 2yr Warranty
ORDER NOW
Key Features:-
Specifications:-
- Screen Size: 27"
- Screen Type: LCD
- Backlight: LED
- VGA Port(s): 1
- DVI-D Port(s): 1
- Energy Star: 5.0
- Warranty: 2yr
ORDER NOW
Specification:-
- Panel Type: TN
- Color Gamut: 72%
- K-Locker: Yes
- Warranty: 2yr
ORDER NOW
Features:-
- LED Backlit
- Height Adjustable
- 5-Port USB3.0 Hub
- VESA Compliant
- Weight: 10.20kg
ORDER NOW
Specification:-
- 21:9 aspect ratio
- LED Technology
- Response: 8ms
ORDER NOW
Features:-
Specification:-
- 30" Widescreen
- Light AG coating
- 10-Bit Colour
- HDMI Input
ORDER NOW
Features:
- LED Backlit
- Full HD
- ACR Capeablity
- Inbuilt Speakers
- HDMI Input
- Overdrive Feature
- VESA Mountable
- VESA Compliant
- Adjustable Stand
- Weight: 5.3kg
ORDER NOW
Specification:-
- Type: PLS LED
- 2x7W Speakers
- USB Hub
- Warranty: 3yr
ORDER NOW
Specification:-
- Type: PLS LED
- 2x7W Speakers
- USB Hub
- Warranty: 3yr
ORDER NOW
