So, I've been reading some radiator round ups (from HESmelaugh for instance) and it would certainly appear that the GTS is an impressive radiator. Is there any particular reason why not to go for it? I have some Sharkoon 2000rpm fans to go on it, which will be on a fan controller, but the radiator does very well, especially considering its size, against the Thermochill and XSPC RX. I'd also guess that having one radiator (GTS) in push-pull would produce better dT's at high RPM than the Thermochill or RX with single fans in push (I only have ~90-100mm room, so the TC and RX are too thick to do with 2 fans, whereas the GTS can take 2 with a little room to spare)?
