Hi, I have suddenly found myself with a black line around the edge of my screen, most prominent at the sides and bottom.
I use my HDTV as my monitor, and normally everything fills the screen right to the edges. However, I went to start up lost planet 2 but on the main menu screen my mouse/keyboard/gamepad all failed to have any effect, so I ctrl+alt+deleted and logged off. I then logged back in and the black line around the edge of my screen had appeared. I then restarted my computer to see if it would fix it, but no good.
I have a 6950 GPU and run windows at 720p for desktop use.
Anyone got any idea why I suddenly have a black line about 0.5cm around the edge and how to fix it?
thanks.
thanks.
