Black ops 2 control issues
26 Mar 2009
Ashington , N/land UK
Just finished playing Ghost recon and no issues, installed BO2 on pc and I am having control issues on the first level :(
1) woods hides behind log, move to shack and would not run so always got caught...restarted level
2) Got to the point where you had to jump onto barge and would not jump ( checked and changed jump key)....restarted level
3) Got passed the Barge and onto the part that you have to hide behind the log...this is from a save point and straight away without even moving ..we get found.
There is nothing wrong with PC (apart from could do with an updated GPU, but passes the canirunit), so is the control different ( using mouse and KB), Is it just me..
PC spec is
i7 920 DO
Gainward 470
Revodrive x3 240gb 140 gb free
18 GB memory
Logitech wave kb and mouse set ( with good batteries)
Help :)
I had none of these issues in the game, but did have major sound issues, reset everything to default and it worked perfectly. Might be worth a reset of your controls?
Turn your res down loads & then play it & see if it's the same. You may have passed the canirunit test but your system may be struggling enough to cause glitches.
tried the multiplayer and zombies and no issues with control so restarted the game from scratch and it has been fine...not touched any settings
System overall was not complaining about resources, but will see if it continues to be ok...do need to upgrade the gpu at some point
