Black paving - removing weeds from between bricks
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
What is the quickest and easiest way to remove the weeds that have grown between my bricks on my paving?
Table salt will kill anything far better than any weedkiller (and far cheaper!), then just top with sand!
This. I mix the salt with vinegar and use this around my home. Not as fast acting compared to stuff like Roundup or other available off the shelf weedkillers, but much more safer and cheaper.
And it tastes great on chips.
You don't want sharp sand, you want kiln dried sand for block paving. It's really fine.
Ps, don't be lazy! Scrape/pick the weeds out and keep on top of it so you don't have this monstrosity of a job again, then just top up the sand as and when needed.
Rather than buy roundup, get some glyphosate concentrate on eBay and a sprayer. Works out 1/10 the price and you can mix it up to different strengths depending on what you need it for. Kills most anything.
