Moved this from my thread in graphics card (where i ask whether my psu is enuff for a 290)
Well after changing to IE for watching netflix all was fine as i thought it was a problem with Chrome. So i loaded up Dark souls (using big picture view on steam) and after about 15 minutes i get the black screen issue again.
(sound and game continues keyboard, controller, mouse lock up though)
What i find weird is that if there was a psu power issue then it surely should have surfaced in the first couple of weeks when i was using the pc with the new 290 graphics card.
Had a look in event viewer but not really sure how to pinpoint the problem
I know black screen crashes are usually classic case of either drivers, ram, or psu right?
Why would the system be working fine for a couple of weeks with new card and then suddenly start doing this? Perhaps i should do a system restore maybe i have changed something and its causing this....
hrmm minor update.
So alls been well with the card has been very good
idles at 29 - 30
load usually 60 or 70 (if its something like shadow of mordor)
I was watching netflix on the TV via hdmi to pc and for some reason i get a black screen...the sound continues and the keyboard still seemed to work though i had to do a soft restart (ctrl alt del didnt work) When i unplug and plug in the hdmi cable the tv screen went green..if that means anything?
I find this odd because ive watched netflix via tv and pc for hours at a time last week and everything has been fine.
On latest catalyst 14.12 cataylst omega drivers.
I will try watching netflix on pc and see if i get a black screen on the monitor.
This odd error has not occurred when playing any games (yet!)
