Black Screens / Slowdown - please help
6 Apr 2009
Hi all,
I have recently added a Crucial C300 to my setup, the 64gb model, and have it connected to the marvel sata 6 ports on my asus p6x58d-e.
The port drivers are the standard microsoft ones as I read this was a better option than then Marvel ones.
my windows is installed with AHCI, has the page file turned off (12gb ram) and has write caching enabled.
Finally, I have superfetch disabled and have only Battlefield BC2, 3D Max 2010 and a Photoshop installed on the drive at present.
Everything else is installed on a Western Digital Green 1tb drive.
Now the problem I am having is as follows, after quitting battlefield or any other program, I sometimes get extremely slow loading back into the desktop, and also when pressing CTRL + ALT + Delete to access the task manager, I get long pauses on a black screen (5 -8 seconds) until the menu loads, and then the same long pause while loading task manager, or similarly if I simply cancel and go back to desktop.
This problem also happens when ALT + Tabbing between programs.
I really have no idea what could be causing the problem so could anyone please help.
Thank you :(
