Blackberry Curve 8520 questions
1 Dec 2003
Liverpool
Hello,
Had this for 20mins, couple questions.
My BB Pin: 2152F070
I set up BBM and then added a couple contacts i know (they are under pending)
Then i had a couple friends add me, though i cannot see their invitation or anything to accept/send/revieve messages.
How do i accept? Could you add me to test please
Next question, how can i sync contacts with my PC?
Thanks!
Chris
That sounds weird, I just added you (name Noni, delete me when whatever you need help with is done).
Are you sure you have the BB package on your contract?
Have you tried pulling out your battery and putting it back in the phone?
Have your mates got your pin right?
Usually takes a bit to kick in although depending who you are with...ring them up and make sure you have BIS enabled onto your account...without that that you wont be able to use BBM.
As for synching contacts with your PC??...are you ising outlook??...if so connect the phone to your pc via the usb cable and open up Desktop Manager and in there go to synchronise then click on synch under configuration and just follow the on the screen instructions.
Personally i dont use pc synching anymore...i just synch via google synch which is over the air synching...i dont lose my contacts if my laptop/pc breaks down as its kept all on google servers. Its free and you can download the app from m.google.com, go there via your phone.
