Blackberry Enterprise Server Express - help!
26 Jun 2005
We've recently received 3 BB Bold 9700's and as we have our own Exchange Server I've installed the BBESE software on our SBS 2003 machine. I followed the online guides to during the install and the BB services are running.
However the issue is that I cannot log into the Administrative Services or the Web Desktop. No matter what credentials I put it (known correct ones) it will not load. Any ideas?
These devices are proving to be a headache and a half!
You cannot run BES on a system which has Outlook installed.
Therefore you cannot run it on SBS.
You could attempt to remove office entirely from SBS (It's going to be messy) then install CDO+MAPI.
http://www.microsoft.com/downloads/...31-079A-43A9-BFF2-0A110307611E&displaylang=en
You really do have to follow the installation white papers to the LETTER.
There is a guide here:
http://www.blackberryforums.com.au/forums/microsoft-exchange/281-bes-sbs-2003-a.html
Although it does not to address the fact RIM does no support installing BES alongside outlook.
RIMs own KB on the matter:
http://www.blackberry.com/btsc/sear...Public&dialogID=29728379&stateId=0 0 13979999
According to BlackBerry, SBS 2003 is a supported operating system; http://docs.blackberry.com/en/admin/deliverables/18763/SR_BES_1049532_11.jsp
Besides, SBS 2003 doesn't come with any office applications pre-installed. Any incompatibility between Outlook and BlackBerry Enterprise Server Express is irrelevant unless you deliberately install Outlook on the server (which would be a bad idea anyway).
Outlook is part of the "full" (all discs) SBS install, yes. MOST people whom would set up SBS would put it on unless they knew better.
Disc 5 or 6 iirc.
Interesting, disc 5 is indeed Outlook 2003. That's pretty stupid, considering Microsoft have always recommended against installing Outlook on an Exchange Server.
It doesn't install Outlook on the server, but it does copy the installation files to a share. You can use the SBS connect computer software to automatically install Outlook2003 to the PCs.
I have had the same problem with BES I think it turned out to be that I updated to latest Java and it broke it.
