Blackheads-How do you get rid of them?
  • Thread starter Thread starter Zip
  • Start date Start date
Zip
Zip
26 Jun 2005
Australia
So has anyone got any suggestions?
Ive got the little buggas on my nose and want to know the best way to get them to disappear.
Insanity said:
I cant, there is to many of them and i dont want to be walking around with a bright red nose :)
Edit:Just noticed your from Oz aswell. Glad to see some more of us on here :)
FIRE
:edit: more seriously, lots of soap on it and scratch :\ for some reason this feels like it should work
Better than walkin' around with black dots all over it. :p
And yes, i am Australian... and my previous post was my 500th.
HAPPY 500TH TO MEEEE!! :D
Pore strips for your nose... put it on, leave it for a while, peel it off and it'll pull all the crap out of your nose for you.
You can also get a small brush, a bar of soap, get the brush all soapy and start rubbing it on your nose.
Is there anything to combat the oil aswell?
My skin gets oily very quickly too and i think that is why ive got the blackheads:(
face wash does the trick, the stuff with the gritty stuff in. it should clear ** face up nicely.
well it does pretty good for me
Real men have rugged, craggy faces!
*n
you'll need to use a skin exfoliator/facial scrub... it'll get rid of the dead skin cells and the blackheads at the same time \o/ :o
(dont forget to moisturise after though)
