Blackwidow hyperspeed mini
  • Thread starter Thread starter Deleted member 70857
  • Start date Start date
Does anybody know if there is a green switch version with a UK layout?
I've looked on the Razer site and it doesn't have it listed, but that doesn't mean much as I have a Razer Book with a spec that isn't listed on the site.
Can't see any myself but the US layout is fine anyway, my huntsman TE and ducky before were US. You just have to remember where your @ key is and the hashtag is £ if you set the windows layout to uk. Any particular reason u go clicky? not optimal for gaming if you ever need a small tap left-right to align yourself for a shot/throw
Not a fan of the small enter key at all.
Had an old Blackwidow with Cherry Blues and loved them.
Mostly work on my PC these days with little gaming.
Guess u could always get the US green switch version kb then get UK keycaps or transfer them from an old kb. Extra £30-35 for a razer set or there's quite a lot to choose from on ocers. Looks like it uses the translucent sided pudding version; "Razer Phantom keycap upgrade set"
I'm pretty confident that wouldn't work as the Enter keys are different physical sizes.
