Blackwidow Return / Enter key
Ermmmm...
Wel mine seems big enough :) , it's not one of those single row height keys, it's 2 rows high although not as wide as some return keys that i've seen. I've had no issues finding it even with my poor typing skills :P
I'm loving my new Blackwidow keyboard, very glad that I took the plunge and bought one.
I can't decide between the BlackWidow and the Steelseries 6GV2, although I can't find anyone stocking the 6GV2 right now so I may just go for the BW
The box arrived today.
Solidly built.
The keyboard area is smaller than on a conventional desktop keyboard as mentioned elsewhere.
Keys are tactile but feel flighty coming from a pretty stiff Dell keyboard.
My hands naturally land to the left of where all the keys are, so it'll take a bit of time to get used to I suppose.
Overall, it's much nicer than any membrane keyboard I've used to date, but a little less robust than the super oldskool IBM buckling-spring keyboards of yesteryear. :)
You would think so!
My left hand index naturally rests on the F key (the notched one) and due to the change in spacing I find it's all a bit skewif. Pressing the macro keys when I actually want shift etc.
Still, getting used to it. Clickety clickety clickety.
I used to that on my g15 when I first got it, as I naturally pressed the key furthest over to the left for shift/esc etc. doesnt take long though :)
I would think the blackwidow was pretty expensive, but noticed my g15 rev 2 has gone up by £20 sine I bought mine 2 years ago lol. Still, 50% off voucher from logitech = g19 for £75 on its way :)
