- 19 Oct 2010
I've had some plans drawn up to knock down an old utility room and single car garage and replace it with a larger utility and what will eventually become our home cinema.
It's not happening tomorrow but hopefully the building work will take place at the back end of this summer.
This thread will be documenting it and hopefully used to choose the best kit. It's not a blank cheque book build so we will need to be sensible. A friend did a similar build a few years back, his setup looks and sounds great so i'll be using his kit at a starting point for discussion so you'll know what i'm looking at.
His Kit:
He says "Amp wise you’d look at the 6800 now with a Dirac license" So we'll pencil that in as the Amp we'll start with.
My Room plans:
I might be able to make it 1m longer on the front. Unfortunately i'll have to put some PC equipment and my sim rig across the back side due to having nowhere else to put it.
Ok, that should do for opening the thread.
His Kit:
My Room plans:
