- 15 Apr 2011
Hi all, sorry if this is the wrong section to post in but anyway..
I'll try to make this as short as possible!
I bought a PC from OCUK back in 2008, I've been extremely happy with it but yesterday when i rebooted i got two BSOD's, rebooting a third time to just get a completely black screen, no post is shown or anything.. the monitor goes onto standby mode and just stays like that.
Now before i restarted i updated my Catalyst Control Center to the newest version which i do about once a month for my ATI HD4870 also there was a Windows Update waiting to be installed, i didn't see which it auto-dl in the background, after i rebooted the first time i got the BSOD stating "IRQL_NOT_LESS_OR_EQUAL" so i rebooted again, windows started up to desktop then i recieved another BSOD but didn't catch what it said, after rebooting for the third time i was faced with the blank screen i currently have.
Before all of this i cleaned my PC as i usually do with canned/compressed air, only taking out the graphics card so i could clean the fan and the cpu fan so i could clean the grill of the heatsink. Thinking perhaps i didn't replace the graphics card in properly i powered down and reseated, seems fine, also checked the connection for the cpu fan (altho it's spinning) and was seated fine also.
I then (other than panick immensly!) took out each RAM stick, reseated / powered up and still the same so i switched them around, tried just one stick etc.. still no luck. I flipped the "EZ" cmos switch on the back of my Antec 900 case which apparently is a 'quick' way to clear the cmos on my Abit IP35 Pro XE, hoping that would fix but no luck still
Now i'm totally at a loss as for what to do
i don't recieve any "beeps" though i don't think my motherboard comes with a speaker, checked the header for it and there's not one there but i have an LED "guru" panel instead which gives codes, mine says 9.0. which apparently means its booted fine when checked it my manual though on Abit's code page here it says it could be some kind've fault, please look!!
I emailed OCUK and they don't do any repairs after warranty has ran out which i considered doing although i'm broke at the moment... you guys are my last line of hope, been up all night trying to fix this and it's wore me out/drove me insane
Any help would be appreciated,
Thank you.
i don't recieve any "beeps" though i don't think my motherboard comes with a speaker, checked the header for it and there's not one there but i have an LED "guru" panel instead which gives codes, mine says 9.0. which apparently means its booted fine when checked it my manual though on Abit's code page here it says it could be some kind've fault, please look!!I emailed OCUK and they don't do any repairs after warranty has ran out which i considered doing although i'm broke at the moment... you guys are my last line of hope, been up all night trying to fix this and it's wore me out/drove me insane
Thank you.
