Hi guys, just setup my new water cooling setup.
I am now at the bleeding stage, but finding it abit of a struggle because my radiator is externally mounted on top of my case and my res is at the bottom of my case.
If I leave it running for awhile, the air/bubbles in the tubes disappear, and leaves me with loads of tiny bubbles remaining inside the res. If I tilt my case, so my radiator is on the left side, more bubbles appear, which I assume is the air in the radiator? No matter how many times I do this, it keeps happening.
I am doing this with a plug removed from the top of res, so air can escape, and I am using a D5 Vario pump currently running at speed 5.
At times, it looks like the air is getting pushed into the res, but is getting sucked back around the loop before it goes to the top.
Any tips on bleeding?
Cheers,
Adam
Cheers,
Adam
