12 Aug 2006 at 10:52 #1 FunkyT FunkyT Soldato Joined 27 Aug 2003 Posts 3,464 As title basically... cheers!
12 Aug 2006 at 10:53 #2 t31os t31os Soldato Joined 24 May 2006 Posts 3,824 Location Surrey - UK Do what anyone else would and use google. http://www.google.com/search?hl=en&q=pc+beeps&btnG=Google+Search
12 Aug 2006 at 11:00 #3 FunkyT FunkyT Soldato OP Joined 27 Aug 2003 Posts 3,464 Thanks. Care the explain the following? 2 short bleeps (pause) 8 short bleeps (pause) 2 short bleeps (pause) 1 short bleep (pause) Cheers...
12 Aug 2006 at 11:05 #4 t31os t31os Soldato Joined 24 May 2006 Posts 3,824 Location Surrey - UK Thats why i gave you a google link, plenty of pages to choose from, it depends on which bios you have.
12 Aug 2006 at 11:09 #5 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 32,891 Location Rutland We need to know the motherboard you have for starters
12 Aug 2006 at 11:56 #6 FunkyT FunkyT Soldato OP Joined 27 Aug 2003 Posts 3,464 Thanks lads - problem sorted now. Swapped the video card and it worked fine then put the original one back - perfect
