Blend test fails
Man of Honour
17 Feb 2003
Chelmsford
I've got my Q6600 upto 3.2Ghz (9x356)
On load, the temps on all cores are 57oc each which isn't too bad.
I've ran CPC benchmarks, Futuremark and stress tested all four cores for 5 hours using Orthas Prime with the Gromac CPU test. No errors or failures.
Yet strangely, the Blend test fails immediately when testing all four cores at the same time. Running the test on single, dual or 3 cores in any combination is fine but it's always core#3 that fails when all run together.
I've played about 5 hours of GoW with the setting and everything seems stable.
The vcore is set to 1.4v and the NB has been increased from 1.25 to 1.4v
The RAM is set to 5-5-5-18 at 712MHz receiving 2.1v
Any ideas?
If its vista 64 then I had the exact same problem, wouldn't fail, would just reboot when using blend despite small fft's been 12hr stable. Memory was memtested and showed no errors. I suspected a bug with the memory controller but thats just a wild guess. In the end I just passed it off as a bug and didn't have any problems running anything else.
It would run blend fine on xp64.
I've not had any restarts but it is Vista x64 with 4x1GB memory modules.
I ran prime95 and got the same result. However, it lastest for 3 minutes before it fell failed.
