** BLITZ IS GOLDEN **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some stunning looking RAM from Avexir which will hit our shelves in 1-2 weeks, grab yourself a kit now on pre-order:-
Avexir Golden Blitz 32GB (4x8GB) DDR3 PC3-19200C10 2400MHz Quad Channel Memory Kit (AVD3U24001008G-4BZ1SE) @ £299.99 inc VAT
The highly anticipated Blitz 1.1 is specifically designed for gamers and overclockers alike for extreme overclocking performance. The concept of Blitz 1.1 not only extends the fantastic LED light hue from the Core series but also with extraordinary design for heatspreader. The aluminium extrusion technique is deployed on every Blitz 1.1 module and together with its uncompromising design style; the Blitz 1.1 is ready for outstanding gaming and overclocking potential. Blitz also employs self-assembled, adjustable heat sink spreaders; gamers can uninstall external heat sink for ultimate performance.
This is the ordinary and classic design. With rich red and black heat sink as base, the Avexir logo is carved on the side and covered with alabaster white LED on the top. It's like the sharpest sword waiting and readying to fight for the forces from the dark side. This is aligned with Avexir's values, when its ready then we are momentum.
The Avexir brand is an established manufacturer associated with producing top quality, high-end RAM memory. Avexir is one of the only manufactures in which the factories hand check each module when it comes to overclocking and working in dual and quad channel modes. The modules are packed into elegant boxes only when they pass thorough quality control tests on different systems including AMD and Intel processors. Other manufacturers unfortunately don’t do such controlled hand quality checks, which means users are more likely to encounter a faulty DDR module, which can cause incompatibilities and headache for the user.
New Avexir Blitz 1.1 Original in our oppinion is the absolute best looking memory in the market today. This RAM simply looks truly amazing with a truly unique design with its white LEDs which pulsate and can really set your system apart from others making it truly unique.
Features:-
- Black PCB
- Blitz 1.1 Original High Performance Heatspreaders
- White LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz
- Speed: 2400MHz
- CAS Timings: 10-12-12-31
- Voltage: 1.65v
- Dual Channel Kit: (4x8GB)
- 100% tested in Intel & AMD based motherboards (Only Intel Haswell mainboards for frequencies beyond 2400Mhz)
- Lifetime Warranty
Only £299.99 inc VAT.
ORDER NOW
Avexir Golden Blitz 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001008G-2BZ1SE) @ £149.99 inc VAT
Features:-
- Black PCB
- Speed: 2400MHz
- Voltage: 1.65v
- Dual Channel Kit: (2x8GB)
- Lifetime Warranty
Only £149.99 inc VAT.
ORDER NOW
Avexir Golden Blitz 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001004G-2BZ1SE) @ £89.99 inc VAT
Features:-
- Black PCB
- Speed: 2400MHz
- Voltage: 1.65v
- Dual Channel Kit: (2x4GB)
- Lifetime Warranty
Only £89.99 inc VAT.
ORDER NOW
Gibbo , will they be doing an orange set - something that would match the giga z87 force OC and z97 would be sweet
Nope. We have to limit colours to those which have good demand, making so many different colours and stocking such a large range hurts profits and causes stock issues as some literally do not sell.
So from now on we shall be sticking to mainly Core series is mainstream colours, blue, red, white, yellow etc.
We shall try to have the odd green and orange SKU's where possible but it is hard as to run production of a colour you have to make a large volume to make it worth while and then when you sell only 1-2pc and have to find a way to get rid of the rest its not the ideal solution.
I wouldnt say "Blue" is very mainstream dont see a lot of blue build , and thats because theres isnt any choise of "nice" blue high end overclocking motherboards available for the enthauast
Only recently have ASRock made a half decent looking Blue Z97 motherboard. However, it definately wouldnt be the main choise as a popular brand.
Orange would be a good shout would match very nicely with Gigabyte and Sapphire Cards both of which you see very frequently in builds.
I just glad i can get the blitz at end of month in the red :) ROG Build here we come :)
Yes we already stock those, black/red heatspreader design with white LED, they look absolutely awesome to be honest in the ROG and MSI Gamer boards. :)
:( 179.99 for the solid green lighty one :(
Memory prices have exploded and they keep going up every week and will do so now until end of year.
Plus that kit is a crazy fast kit so in the scheme of things its not such a bad deal. Look at the slower regular stuff, better priced. :)
May have to compromise on the yellow then as I really fancy some for my build.... Are you 100% not getting orange! :D
I personally think orange popularity will grow due to gigabyte going big on orange and boards being v popular now... But yellow could do..
Nice memory, Already have 16GB *4x4*of the Blitz 1.1 Original at 2500MHZ, Doubt I'll be needing anymore anytime soon but it's good to see they are coming out with new stuff :)
PS spot price is starting to come off on DDR3 but there is prob about a 2 month lag from spot price rise to gibbo purchase, so it could be4 - 8 weeks before prices stop rising and come off a bit.. Charts are here
http://www.dramexchange.com/
Pretty irrelevant, were buying from factory and they have informed us prices will continue a steady increase from now to December. Of course price might drop by $1-$2 on IC as a dip on odd day which DRAMEXCHANGE reports but then move up again steadily. At least its being a steady increase and not an overnight double in price as in previous years.
Integrated/MMC/Tablet is taking DDR3 production lines hence the increases and once DDR4 production increases won't help matters either.
I doubt we will see any major reductions now until after Christmas, what won't be happening ever again is 8GB kits for £20 or even £30, doubt they will go below £50 again now.
