** BLITZ IS GOLDEN **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some stunning looking RAM from Avexir which will hit our shelves in 1-2 weeks, grab yourself a kit now on pre-order:-
Avexir Golden Blitz 32GB (4x8GB) DDR3 PC3-19200C10 2400MHz Quad Channel Memory Kit (AVD3U24001008G-4BZ1SE) @ £299.99 inc VAT
The highly anticipated Blitz 1.1 is specifically designed for gamers and overclockers alike for extreme overclocking performance. The concept of Blitz 1.1 not only extends the fantastic LED light hue from the Core series but also with extraordinary design for heatspreader. The aluminium extrusion technique is deployed on every Blitz 1.1 module and together with its uncompromising design style; the Blitz 1.1 is ready for outstanding gaming and overclocking potential. Blitz also employs self-assembled, adjustable heat sink spreaders; gamers can uninstall external heat sink for ultimate performance.
This is the ordinary and classic design. With rich red and black heat sink as base, the Avexir logo is carved on the side and covered with alabaster white LED on the top. It's like the sharpest sword waiting and readying to fight for the forces from the dark side. This is aligned with Avexir's values, when its ready then we are momentum.
The Avexir brand is an established manufacturer associated with producing top quality, high-end RAM memory. Avexir is one of the only manufactures in which the factories hand check each module when it comes to overclocking and working in dual and quad channel modes. The modules are packed into elegant boxes only when they pass thorough quality control tests on different systems including AMD and Intel processors. Other manufacturers unfortunately don’t do such controlled hand quality checks, which means users are more likely to encounter a faulty DDR module, which can cause incompatibilities and headache for the user.
New Avexir Blitz 1.1 Original in our oppinion is the absolute best looking memory in the market today. This RAM simply looks truly amazing with a truly unique design with its white LEDs which pulsate and can really set your system apart from others making it truly unique.
Features:-
- Black PCB
- Blitz 1.1 Original High Performance Heatspreaders
- White LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz
- Speed: 2400MHz
- CAS Timings: 10-12-12-31
- Voltage: 1.65v
- Dual Channel Kit: (4x8GB)
- 100% tested in Intel & AMD based motherboards (Only Intel Haswell mainboards for frequencies beyond 2400Mhz)
- Lifetime Warranty
Only £299.99 inc VAT.
ORDER NOW
Avexir Golden Blitz 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001008G-2BZ1SE) @ £149.99 inc VAT
Features:-
- Black PCB
- Speed: 2400MHz
- Voltage: 1.65v
- Dual Channel Kit: (2x8GB)
- Lifetime Warranty
Only £149.99 inc VAT.
ORDER NOW
Avexir Golden Blitz 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001004G-2BZ1SE) @ £89.99 inc VAT
Features:-
- Black PCB
- Speed: 2400MHz
- Voltage: 1.65v
- Dual Channel Kit: (2x4GB)
- Lifetime Warranty
Only £89.99 inc VAT.
ORDER NOW
