Block bitlord though router
6 Jul 2006
England, Stafford
Hi ya just bought a Netgear wireless router DG834PN, and i am wanting to block bitlord from download and upload at certain times due to my isp fair use stuff, tho i do not know what to block, the port that bit lord goes thoght is 16305, the problem is i do not know which one to pick in the item menu
here is a link to a pictuer of all the ports could you tell me which one to block
http://i82.photobucket.com/albums/j260/richardvaughan/RouterPorts.jpg
the second link is a link to some other stuff do in need to fill this in as well or leave it blank
http://i82.photobucket.com/albums/j260/richardvaughan/Doineedtofillinthisbit.jpg
thx for the help
How about you stop the download from downloading at the certain time and stop your downloaded files uploading at the certain time manually?
Try not using Bitlord because most decent torrent sites have banned it for being dodgy. Gor for Azureus if your system can handle it or utorrent if it can't. Both of those have fairly good scheduling options.
uTorrent has some good scheduling options. The missus downloads a lot of torrents and I was getting fed up of her leaving uTorrent open all the time, saturating our upstream and killing our network as a whole. Have just configured our d/l PC so that anything she queues won't start until after midnight, and will stop again at 7am.
You can also set "limited" time periods where you can force the max download/upload speeds for that time period.
Andy
Az is resource heavy, but newer versions have reduced it a bit. utorrent is a bit basic option wise though, its like the fisher price of BT clients. :D
