In theory, block paving shouldn't need sealing as the blocks are so close to each other, having been laid on a sand base. The previous post is correct that sand is just brushed over them to finish the job. You may get the occasional weed growing in the joints, but these can be easily pulled out as the roots will be shallow. Any persistant ones can be sprayed with weed killer.
