Blocked Shower Drain
10 Nov 2016
Has anyone ever used one of these to unblock a shower drain?
http://imgur.com/nCRamab
nCRamab
I havent used one, but I have recently taken to using my wet and dry shop vac which works a treat. Now if only my wife would let me shave her head, I wouldnt have to do it at all! :)
I use a barbed plastic one (looks like a super long cable tie with barbs), got it on the rainforest for £2. Works a treat on getting the wifes steel wire reinforced hair out the plug.
I've used one of those snakey things in the past yes, when we moved into a rented flat the bath was very slow to drain.
The amount of sludge and nastiness I got out of the plug physically made me vomit, the smell was unbelievable! I'm sure someone was pooing in the bath! That's what the sludge looked and smelled like!
It did the trick. Dragged up a big wad of gunk and long hair.
But forgot to o-ring back on when screwing the plug assembly back together. nearly flooded downstairs having a shower before I realised.
Lesson learned. Call a plumber.
Seriously don't call a plumber just clean your shower regularly and buy a plunger that would almost certainly have cleared it without any dismantling!
