A[L]C said:
A[L]C said:all they need to do then is open IE to bypass it! K9 also has time restriction
A[L]C said:
GraemeUK said:Not if you uninstall it and put them on a limited account so they can't reinstall it![]()
Rich43 said:I would just put in a ubuntu cd.. bypassed!
I dont see the point.. gonna learn one day![]()
GraemeUK said:Not if you turn off boot from cd and make first boot device the hdd and password the bios.
sorry had to be said, dont mind me I will get my coat :/
Or, read post 13 and not install or try anything thats not alredy on your pc.JayMax said:So to summarise, the options are:
1. Install Firefox, then install extensions, then uninstall IE, then make the user a limited account, then password protect bios, then disable boot from cd and then, finally, weld the case shut so the battery can't be removed![]()
or
2. Install K9 web protection. Which considering it's free is an excellent product.
No brainer tbh.
not really. Content advisor doesnt have any time restrictions does it?brendy said:Or, read post 13 and not install or try anything thats not alredy on your pc.
