Blocking Limewire
7 Mar 2005
Wolverhampton
Hey guys, anyone know how to block limewire? Not sure how to do it through my router CP.
I'm using WRT54GL with Tomatoe firmware 1.17.
Cheers :)
Firewall rules, but it isn't particularly effective - change the port and you get around the rule.
You might be able to set up Layer 7 packet inspection, so the router knows it's from Limewire regardless of port. Depends whether Tomato supports it.
I just block everything except 80 and 443 outbound on my network, my PC's ip is in the exclusion list for this rule. I did it in tomato using access restriction.
