blocking on FN3
25 Nov 2004
i cant block :| im using config 3 and the back right trigger is block...but it doesn't work :s anyone else having same trouble?
yea, you can either block or parry.
Top right of stick parries left handed shots, top of right stick = total block, e.t.c
same with the bottom section too, and likewise with the lean
ignore the forums mate, bunch of plastic fans. Get rid of Rafa, get rid of crouch, e.t.c all *******.
We do need 2 strikers, and a right winger though, but Rafa is the man :)
Back to the blocking.... ;)
Are you saying you should sort of lean in the direction of the punch? So if he punches low-right (your right), then should you lean towards the punch?
It seems if you move your body away from the punch then it still lands!
If I can just master blocking then i'm sure I can take him down in the 1st round :D
