Blocks on TIM or pads ?
10 Oct 2006
N.I.
Should i mount my heatkiller blocks onto gtx480 using TIM or pads ?
I have plenty of MX2 compound, dont have any pads as blocks are used.
Fair points on all suggestions.
So, next question is "what is best pad"? Which brands i should be looking at ? Best thermal conductivity...
Also, what thickness pads used to mount full cover blocks ? 1mm ? 2mm ?
You need to check with the block manufacturer to what thickness pads you need, brand is generally irrelevant.
Yeah, already checked that. 0.25 and 1mm.
What/where should i get ?
Checking out ebay yields multiple choices plus info on w/mk. Max of which i've seen is 7 w/mk. How good/bad is it ? What are max w/mk for thermal pads ? Been reading on some german forums that there are up to 17 w/mk, but i cant find any...
