**Bloody silly Prices B-Grade Soundcards**
7 Feb 2011
Stoke on Toast
Sadly a limited amount of these (1 of each) but figured I'd let you all know i've adjusted the pricing to be more reasonable.
Condition is unknown expect just a soundcard + anti static bags you might get the box if you are lucky.
**B Grade** Asus Xonar DX 7.1 PCI-Express Sound Card @ £24.95 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscape has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar DX driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar DX audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 116dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar DX is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Unprecedented SSNR NR Up to 116db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Legally backup your digital music into non-protected MP3/WMA files with even better quality and Dolby Headphone and Virtual Speaker effects
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Low Profile Bracket Included
- Vista Ready
The warranty on B-Grade products is 90days with Overclockers UK and any left over warranty is with the manufacturer.
Only £24.95 inc VAT.
ORDER NOW
**B Grade** Asus Xonar DGX 5.1 PCI-Express Sound Card with built in Headphone Amp @ £9.95 inc VAT
The Xonar DGX sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DGX an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
- PCI-E
Originally sold at £22.49+VAT
Only £9.95 inc VAT.
ORDER NOW
**B Grade** Creative Sound Blaster Audigy SE 7.1 Sound Card - OEM @ £9.95 inc VAT
The Sound Blaster® Audigy™ SE is an excellent value upgrade to 7.1 surround sound on the PC. Featuring high quality audio specifications including 24-bit/96kHz recording and playback with 100dB signal to noise ratio and digital output, it's the ideal partner for surround music and movie playback. For realistic gaming, EAX® ADVANCED HD™ 3.0 support delivers acoustic effects and detailed 7.1 3D surround sound in gaming. The included Creative Media Source™ software is a comprehensive tool for creating MP3s, managing a music collection, adding effects and burning custom CD compilations.
- 7.1 surround output
- 24-bit/96kHz audio resolution
- 100dB signal to noise ratio
- Comprehensive Creative Media Source software provided
- EAX ADVANCED HD 3.0 support for gaming
- CMSS up-mixes stereo content to 7.1 surround
Originally sold at £15.95+VAT
Only £9.95 inc VAT.
ORDER NOW
Would the sound blaster provide better audio than the onboard sound of an asus m5a99 fx pro r2.0? I'm thinking about buying that one if it does.
You tried any other available PCI-e slots littlepuppy? Even 4x and 16x slots would work.
I've had issues with cards not being recognised on quite a few boards in the past and moving slots has helped.
Hope you get it sorted. :)
Tried it in a 16 x slot.. Ill try an alternative one now... It just wont be hidden now though!
EDIT, Not going to try it... My build is super neat and I dont want it (with its power adapter trailing into the middle of my case)
Its goin back...
Well ordered a Phoebus instead, hopefully that will work fine..
Cant fault OCUK speed though, RMA is already raised :D Cheers bailey.
yes everything is better than onboard in my experience and for 9.95 it can't be a terrible idea.
Littlepuppy sorry to hear that, things that are broken shouldn't be going back into B-Grade as most of our b-grade stock comes back from suppliers as NFF or returned in a poor condition faulty items shouldn't be there :(
TBH mate, I have had - probably - at least 20 items from B grade over the last 2 years and I would say 2 have been faulty and 1 was not what I was after in the end, so most of the time it works out... This looked better than usual, box, driver disk etc etc.. Just didn't play..
I do realise though B grade can be a bit of a lottery and most of the time its worth the risk, so no hard feelings here, the financial savings make up for it in most cases! :D
Ordering in a sec :) I too have had a b grade 120mm xspc radiator slight scratch and no screws but otherwise perfect. Couldn't fault it for price.
Tempted, but I dont think I'll have any joy with my setup as I've got SLI gpus on an ASUS formula mobo (Z87 chipset)
Its probably worth pointing out that the Audigy card is PCI and although shows in the pic its not stated in the specs ;)
I've got 1x pci slot on my board. Does it look like a pcie lane but sort of the wrong way round?
My board is the asus m5a99fx pro r2.0 and I mean the light blue slot second up from the bottom on the board.
Is there any difference in sound quality between pci or pcie. I've ordered it by the way and grabbed a b grade fx4300 for a pc I'm selling for £65 too :)
No sound quality difference no.
