Blow up....
20 Nov 2016
That got your reading lol
Anyone got any experience / recommend a blowup paddle board.
Looking to spend max 300, sea use only mostly in bays so nothing in terms of swell for summer paddles.
I'm 5,8 approx 10stone so no idea what length I need??
Thx
You do realise that just by posting this thread title,
that you are now on a Special Branch Watch List?
Thx
Go for a 10 foot board (you are the same height as me plus I am a bit more heavier than you are) & when you set the paddle length, stand the paddle vertical and adjust the handle end so it is 6 inches above the top of your head.
I have a Naish 10 foot mana fibreglass board with a fixed shaft paddle hence the above tip had to cut mine down.
Cheers all
Cheers all
Thank you, I imagine hard board is more stable/buoyant?
Yes more stable, but the inflatable is more portable, but with the inflatable you can keep it in the boot of your car all the time etc.
Cheers all
