Blower cards?
Case temps are down to case airflow.
A blower in a midget ITX is helping with case temps more than an open fan cooler sharing the heat around.
But you stick a blower in a massive EATX case with a wall of case fans, is that blower really meaningful compared to the excessive airflow going through the case anyway.
do blower fans dump all 100% heat out the back or is there still some left in the case?
Blower fans will definitely help case temps vs a 2/3 fan dumping heat inside the case as the majority of the heat is exhausted with a blower design.
However, they will still put some heat in the case. They are also louder too as it's 1 fan vs 2/3 fans.
