Hi all,
I had a charger for my phone plugged into my cigarette lighter which continuously blew the 10a fuse after working for over a year, I presumed the charger was broke and borrowed one to test in my car, this one worked fine. I then bought a new charger and the amp is continuously being blow again..
Is there a specific thing I should look for or should I just refer to an auto electrician. I don't understand why one charger would work but the other two don't.
I presume sticking a higher amp fuse won't rectify this?
Cheers
Cheers
