BLOWING OUT THE DOOR! EPICNESS ON FANS!
20 Jul 2009
The bleak North East arm pit of Britain
These are blowing out of the warehouse at gale force speeds!..
:D
Check these beasts out!
BeQuiet SilentWing USC 80mm Fan @ £9.98 inc VAT
When developing the new generation of our housing-fan series SilentWingsUSC, two things were of particular importance to us: that they should run extremely quietly and at the same time achieve optimum airflow - an extremely tricky challenge.
And with the newly developed Ultra Silent Concept (USC), we have mastered this challenge. The USC comprises, amongst other things, two Innovations from be quiet! protected by german utility patent. In addition, the housing fan has a remarkable lifespan of almost 300,000 hours.
But, of course, our SilentWingsUSC exhibit other features, too. That's why the 80-mm SilentWingsUSC came out on top in a comparative test by PCGH, and as a result was awarded top product - another result of our work into which our knowledge and, more importantly, our entire passion goes.
- Screwless anti-vibration fixtures and rubberised fan frame protected by german utility patent
- Quiet operation thanks to the reduction of vibrations and simple installation without tools
- Minimisation of electrical noises at a constantly high running smoothness
- Fan Speed: 2000 RPM
- Air Flow: 26.0 or 44.20 CFM
- Noise Levels: 15 dBA
- 3 Pin Molex
- 3 Year Warranty
Was £11.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Antec Tri-Cool 3-Speed 120mm Fan - Black @ £2.59 inc VAT
No matter what type of fan you're looking for, the Antec TriCool line offers reliable, stable performance. Available in 80, 92, and 120mm, TriCool fans offer the perfect balance of silence and efficiency. TriCool fans feature a 3-speed switch so you can find the ideal equilibrium of quiet and cooling.
- 3-speed switch lets you balance quiet performance with maximum cooling
- 4-pin power connectors provide convenient connections to your motherboard or power supply
- Fan-speed monitoring capability included (requires compatible motherboard)
Was £3.98 Inc. VAT
Only £2.59 inc VAT.
ORDER NOW
Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin @ £4.99 inc VAT
Near silent 12 cm fan with distinctive Emperor Blue coloured rotor blades and crystal clear frame. Designed with low air impedance blades providing the ultra quiet acoustic experience.
- Dim: 120 x 120 x 25mm
- Rated speed: 1400 RPM
- Sound: 18.0 dB(A)
- Air flow: 49.74 CFM
- Bearing: Sleeve Bearing
- Life expentancy: 30,000/ hrs
Was £5.99 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
Akasa AK-FN059 120mm Ultra Quiet Venom Viper Cool Fan - 3/4 Pin @ £11.99 inc VAT
High performance 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Viper fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. Killer Viper yellow colour makes this fan distinctive and unique.
- High performance 12cm fan in killer VIPER yellow colour
- S-FLOW fan blade design delivers 30% higher airflow
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension: 120 X 120 X 25mm
- Fan speed: 600 -1900 RPM
- Max airflow: 83.63 CFM (141.75 m3/h)
- Max static air pressure: 2.98 mm H2O
- Noise level: 6.9 -28.9 dB(A)
- Fan life expectancy: 50,000 hours
- Connector: 4pin PWM
Was £13.99 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Akasa AK-274CB-4BLS 120mm Blue LED Fan @ £8.99 inc VAT
This is an ultra quiet 12cm case fan delivering high air volumes with an incredible acoustic performance of only 17.5dB(A). The Cool Blue look is achieved by four hi-bright blue LED complemented with crystal blue frame and blades.
- Application PC Case fan
- Frame dimension 120 x 120 x 25mm
- Fan speed 1200 RPM
- Fan airflow 38.4 CFM
- Fan air pressure 1.17 mm H20
- Fan life expectancy 20000/hrs 25ºC
- Bearing type Sleeve Bearing
- Connector 3-pin with RPM sensor wire
- Voltage rating 12V
- Current rating 0.15 A
- Noise level 17.5 dB(A)
- Product code AK-274CB-4BLS
Was £11.22 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM @ £11.99 inc VAT
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum. The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It’s powerful, quiet and tough!
- Super silent APACHE fans in Black Stealth colour
- IP-54 military standard moisture and dust protection
- Dimension 120 X 120 X 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 -1300 RPM
- Max airflow 57.53 CFM (97.74 m3/h)
- Sound level 6.9 -16.05 dB(A)
- Max static air pressure 26.40 mm-H2O
- Rated voltage 12V
- Connector PWM-4pin
Was £13.99 Inc. VAT
ORDER NOW
Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM @ £8.99 inc VAT
PWM is a widely available feature on all current Intel and AMD platform based motherboards. It is more accurate than voltage regulation, energy saving and a fully automatic way of controlling the fan speed. PWM provides ultra quiet acoustics during normal PC use and high performance cooling under high system load. The Optional Akasa AK-CB002 cable adapter can provide the system with two additional PWM connectors if needed.
- Super silent APACHE fans in camouflage colours
- Rated voltage 12V
Was £9.98 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Akasa AK-274CG-4GNS 120mm Green LED Fan @ £5.99 inc VAT
his is an ultra quiet 12cm case fan delivering high air volumes with an incredible acoustic performance of only 17.5dB(A). The bright Green illumination is achieved by four hi-bright green LED complemented with a crystal green frame and blades.
- Product code AK-274CG-4GNS
Was £6.99 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
BeQuiet SilentWing USC 120mm Fan @ £9.98 inc VAT
But, of course, our SilentWingsUSC exhibit other features, too. That's why the 120mm SilentWingsUSC came out on top in a comparative test by PCGH, and as a result was awarded top product - another result of our work into which our knowledge and, more importantly, our entire passion goes.
- Fan Speed: 1500 RPM
- Air Flow: 50.5CFM
- Noise Levels: 17 dBA
- 3 Pin Molex
- 3 Year Warranty
Was £14.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Coolermaster 120mm Fan - Black @ £1.99 inc VAT
Case cooling is becoming more essential these days. The better airflow inside your system, the cooler and more stable system you will get. This fan provides Silent operation and higher air flow to enhance cooling performance.
- Dimension (W / H / D): 120x120x25mm
- Speed (R.P.M.): 1200 R.P.M. ± 10%
- Air Flow (CFM): 44.03 CFM ± 10%
- Air pressure (mmH2O): 1.83 mm H2O ± 10%
- Fan Noise Level (dB-A): 19.8 dBA
- Weight: 120g
- Bearing Type: Sleeve
- Fan Life Expectancy: 30,000 hours
- Connector: 4 pin
- Cable Length: 300mm
Was £2.99 Inc. VAT
Only £1.99 inc VAT.
ORDER NOW
DeepCool UF-120 Ultra Silent 120mm Fan with Anti-vibration TPE Cover @ £8.99 inc VAT
- Strong plastic frame with soft and elastic TPE cover to absorb vibrations
- Special fan blade design to offer a unique visual effect when operating
- Two ball bearing to offer smooth rotation and long lifetime
- Super silent and big airflow
- Overall Dimension: 120 x 120 x 26mm
- Net Weight: 172g
- Bearing Type: Ball Bearing
- Rated Voltage: 12 VDC
- Operating Voltage: 10.8 to 13.2 VDC
- Started Voltage: 7 VDC
- Rated Current: 0.13 ±10% A (MAX)
- Power Input: 1.56W
- Fan Speed: 500 RPM ±200 to 1500 ±10%
- Max Air Flow: 66.3 CFM
- Noise Level: 17.6 to 27.8 dB(A)
- Warranty: 24 months
- EAN barcode: 6933412704157
Was £12.98 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Scythe Kaze Jyuni 1900RPM Slip Stream 120mm Fan @ £7.99 inc VAT
The Slipstream 120mm Case Fans have been developed solely by Scythe engineers. They found out that by reducing the dimension of the centre hub and the wider surface area of the fan blade increased the airflow. There are a range of different fan speeds to choose from which meets the demand from a wide variety of users in the market. Silent users to power users now have more choice when it comes to choosing a suitable case fan.
- Air volume at full speed (12V), CFM ±10% 110.3
- Noise level at full speed (12V), dB(A) 37.0
- Fan speed at full speed (12V), RPM ±10% 1900
- MTBF 3.5 years
Was £8.99 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
Scythe Kaze Jyuni 1200RPM Slipstream 120mm Fan @ £6.98 inc VAT
- Air volume at full speed (12V), CFM ±10% 68.5
- Noise level at full speed (12V), dB(A) 24.0
- Fan speed at full speed (12V), RPM ±10% 1200
- MTBF 3.5 years
Was £8.50 Inc. VAT
Only £6.98 inc VAT.
ORDER NOW
Scythe Gentle Typhoon 120mm 1150 RPM - 3 Pin @ £10.49 inc VAT
The GentleTyphoon achieves high airflow volume and low noise with the newly designed impeller, enabling silent cooling of the latest devices which run very hot.
The GentleTyphoon has a different type of tone. The fan propeller is designed to reduce the disturbing frequency fan noise to human ears. The newly designed motor and motor support mechanism of the GentleTyphoon uses a double vibration reduction structure. The new support mechanism uses coil dampers to greatly reduce vibration.
- Manufacturered in Japan
- Only 21.0 dB(A) at 1150 RPM
- Weight 200 g
- Dimensions 119 x 119 x 25 mm
- Air volume at full speed (12V), CFM ±10% 37.1
- Noise level at full speed (12V), dB(A) 26.0
- Fan speed at full speed (12V), RPM ±10% 1150
- Bearing Type Double Ball Bearing
- MTBF 100,000 hour at 35°C or 60,000 hours at 60°C
- Accessories 4-pin Molex Adapter, 4x Screws
Was £12.98 Inc. VAT
Only £10.49 inc VAT.
ORDER NOW
Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin @ £11.99 inc VAT
- Model-No. D1225C12B4AP-14
- Only 21.0 dB(A) at 1450 RPM
- Weight 200 g
- Air volume at full speed (12V), CFM ±10% 50.0
- Noise level at full speed (12V), dB(A) 21.0
- Fan speed at full speed (12V), RPM ±10% 1450
Was £12.98 Inc. VAT
ORDER NOW
Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin @ £11.99 inc VAT
- Only 21.0 dB(A) at 1850 RPM
- Weight 200 g
- Air volume at full speed (12V), CFM ±10% 58.0
- Noise level at full speed (12V), dB(A) 28.0
- Fan speed at full speed (12V), RPM ±10% 1850
Was £12.98 Inc. VAT
ORDER NOW
Scythe Gentle Typhoon 120mm 5400 RPM Cooling Fan, D1225C12BBAP-31 @ £18.98 inc VAT
Gentle Typhoon 120 mm High Speed Series are optimised for high speed as well as high airflow. An implemented ring connects the fan blades creating characteristics similar to 38mm thick fans, while running at a quieter noise level. By employing a large fan motor, little fluctuation in rotation torque has been achieved. Furthermore a vibration absorbing structure has been integrated to further help reduce the noise level.
Optimized for High Airflow
Forceful airflow is created and guided in a linear fashion thanks to the implemented stabilising ring. By using this powerful design the fans are able to generate high pressure to overcome and handle high resistance such as when being used with a duct or coolers with dense fin structure.
Vibration Reduction Structure
By employing a large fan motor, little fluctuation in rotation torque has been achieved. Furthermore a vibration absorbing structure has been integrated to further reduce the noise level. This combination greatly reduces the transfer of vibration from the motor to the fan chassis.
- Weight: 205 g
- Dimensions: 120 x 120 x 25 mm
- Maximum air flow, CFM ±10%: 150.1
- Maximum noise level, dB(A): 50.5
- Maximum fan speed, RPM ±10%: 5400
- Power Consumption: 13.68 W
- Rated Current: 1.14 A
- Starting Current: 2.69 A
- Cable Length: 30 cm
- Bearing Type: Double Ball Bearing
- MTBF: 100,000 hour at 35°C or 60,000 hours at 60°C
- Accessories: 4-pin Molex Adapter, 4x Screws
Was £19.99 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Akasa AK-FN062 Apache Black Super Silent 140mm Fan - 4 Pin PWM @ £12.98 inc VAT
Super silent 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction.It’s powerful and quiet!
- Super silent APACHE BLACK 14cm fan
- Super silent with PWM speed control
- Application: PC case or heatsink fan
- Dimension: 140 X 140 X 25mm
- Fan speed: 600 -1300 RPM
- Max airflow: 89.55 CFM
- Max static air pressure: 2.76 mm H2O
- Noise level: 12.5 -22.19 dB(A)
- Voltage rating: 12V DC
- Bearing: HDB (Hydro Dynamic Bearing)
- Product code: AK-FN062
Was £14.99 Inc. VAT
Only £12.98 inc VAT.
ORDER NOW
Akasa AK-FN063 140mm Ultra Quiet Viper Cool Fan - 3/4 Pin @ £12.98 inc VAT
High performance 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
- High performance 14cm fan in killer VIPER yellow colour
- Fan speed: 600 -1600 RPM
- Max airflow: 110.61 CFM
- Max static air pressure: 3.12 mm H2O
- Noise level: 12.5 - 26.01 dB(A)
- Product code: AK-FN063
Was £14.99 Inc. VAT
ORDER NOW
BeQuiet SilentWing USC 140mm Fan @ £11.99 inc VAT
- Fan Speed: 1000 RPM
- Air Flow: 60.4 or 102.7 CFM
- Noise Levels: 16.5 dBA
- 3 Pin Molex
- 3 Year Warranty
Was £16.99 Inc. VAT
ORDER NOW
BitFenix Spectre 140mm Fan - White @ £7.99 inc VAT
Introducing the Spectre™ Non-LED Fan Series from BitFenix. Engineered for both silent operation and maximum airflow, Spectre will keep your entire system well ventilated without making it sound like an airplane hanger. Spectre Fans are designed with sickle fan blades, which enhance airflow without producing excess noise. Fluid dynamic bearings reduce friction for long life and quiet operation, while an attractive matte finish gives your entire system a look that's second to none.
- Dimensions (mm): 140 x 25
- Current (A): 0.10
- Speed (RPM): 800-1000
- Air Flow (CFM): 60
- Noise (dB-A): 18
- Air Pressure (mmH2O): 1.93
Was £9.98 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
Oh jeez!
Whats the fan with the largest cfm and static pressure you have? Size is not important.
Would happily go upto a 240mm fan size.
