Caporegime
- 8 Jul 2003
- In a house
Turned the PSU switch on to get her booted, made some crackles, wouldn't fire up, did the cardinal sin, unplug, replug, try again, eventually came on, rig booted, popped downstairs for a bit, by the time i came back up, rig had gone off, PSU was deed.
Good job i had my old rig with a Corsair AX860w in it, so i just swapped it over, and to my surprise, it booted up fine, no messages about wasn't shutdown properly, nowt, just booted straight to my desktop, like nothing had happened, phew!
The PSU was a TT Toughpower, RGB 850w Grand Sync, which id only had for 15 months, so luckily still under guarantee, but i'll be steering clear from em, and sticking to me Corsair for now.
Remember all, if your PSU goes dodgy, just get it swapped for another straight away, or you might not be as lucky as i was, with everything else still working after a swap
