Hello overclockers, I know I might be cheeky in asking for some help with my very first post but I need it
I don’t have that large a clue about WC other then the bits I have read on here. So basically I was interested with setting up a system that could adequately cool a CPU and GPU and also fit a NZXT Phantom case.
Spec:
NZXT Phantom
ASUS Crosshair Formula V
AMD Phenom II X4 955 (OC @ 3.8)
AMD MSI HD 7970 (OC @ max CCC limits)
OCZ ZX Series 850W PSU
The only part that I know for sure I like the look of is the Phobya balancer 150 black nickel reservoir, unless someone can say something that’s better. Also as a side note I was planning on maybe upgrading the CPU to Ivy Bridge later on once its out if it fairs well with games. So that will likely be something to consider as a later thing of the WC system.
As for a budget was thinking of the £300 to £400 area but if that isn’t possible then I will think of maybe expanding the funds or just concentrate on cooling the graphics card and get the CPU items later. I had been looking at the kits on overclockers as well but wasn't sure if that would cool a system like mine well enough.
Cheers for any replies
BLT
I don’t have that large a clue about WC other then the bits I have read on here. So basically I was interested with setting up a system that could adequately cool a CPU and GPU and also fit a NZXT Phantom case.Spec:
NZXT Phantom
BLT
Might just copy what parts they used to water cool theirs but just wanted to make sure that it could cool my system enough
if I was more competent then I would have moded the Phantom by now. Even removing the HDD cage at the front I can see me messing that up.
