Hi all,
Over the weekend I upgraded my machine from a 6700k to a new motherboard and Ryzen 3900x. I didn't reinstall windows because everything seemed to work fine (never had that before after such a drastic upgrade!). I know you are meant to do a fresh install but I thought I'd see if I could get away with it. As I said everything is working fine apart from my blu-ray drive.
When I put a disk in it takes probably 5 minutes to even recognise it. It won't even let me access it. Cyberlink says I don't have a drive but it shows up in the bios and device manager.
I have tried uninstalling it and reinstalling it. I have uninstalled all dvd software. I have also reinstalled windows (not a fresh install, the one that keeps files and apps). I know the drive works because I plugged it into an external drive sata and power caddy and ran it through usb and it works like a dream. I have also made sure all my drivers are up to date and have flashed my bios to the latest version. I'm really at a loss! I know blu-ray is so 2006 but I have a bunch of rare movies on bluray.
There was a note in device manager about it not being migrated but after fiddling for a while that has changed to syaing it has been migrated but still no luck.
Any help would be much appreciated!
ASUS x570 gaming-plus
Ryzen 3900x
GeForce 3090 FE
80gb ram
Pioneer BD-RW bdr-207
Ryzen 3900x
GeForce 3090 FE
80gb ram
