Hi what are your recommendations for flexible software for 24fps blu ray playback on multiple monitor configurations
(laptop screen fixed 60hz, secondary screen 24hz p2270hd, hdtv supporting 50/60hz)
50hz needs frames sent twice and 5% speed-up
60hz needs successive frames sent for 3 and 2 refreshes giving associated judder
72,120hz need frames sent 3,5 times
Contenders seem to be
comments
1. anydvdhd has benefit of giving multiregion playback
2. can try genuine frame interpolation for 50/60hz http://www.tested.com/news/how-to-enable-motion-interpolation-on-your-movie-files/329/
I do not have sufficient cpu horsepower for this; anyway sky hd apparently adopts speed up approach
(maybe they have better s/w than re-clock for audio speed-up)
3. previous thread discusses (free-ware) makemv5 ripper; can this be used to rip blu-ray sufficiently fast and then playback with mpc-hc
but need lots of free disc space (it appears makemv5 is no no longer free from September so benefit gone)
4. concern for native windvd/powerdvd/tmt3 24hz/50hz support is that the data is always sent at 60hz and get image tearing.
5. powerdvd & tmt3 apparently work with reclock (windvd does not) so maybe they can do 50Hz or ... reclock just gives them basic 60hz vsync
capability ?
5. (other than interpolation) no good/judder-free solution for 60hz laptop
... are there laptops with changeable frequency
Perhaps there are other significant distinctions between players.
- interface on mpc-hc is less elegant than winddvd/powerdvd/tmt3 but multi-region benefit seems to make it compelling
- anydvdhd has regular updates for new AACS/encryption keys
- ability of players to exploit hardware acceleration
[an online light-weight review
http://www.reviewmaze.com/2010/06/windows-blu-ray-players-comparison.html]
Code:
[FONT="Fixedsys"] 24hz 50hz 60hz 72 hz
MPC-HC + andvdhd x with reclock [Previous thread 'MPC-HC plays blu ray discs just fine..' had some data on this ]
windvd x
powerdvd x
tmt3 x
splash player [ [url]http://mirillis.com/en/index.html[/url] ][/FONT]
comments
capability ?
