Blu Ray Streaming
30 Dec 2010
I am considering putting my blu ray collection on hard disk and having the ability to stream it to the tv downstairs and elsewhere. I've a wired network setup for streaming already and presume cat5 to be sufficient to do the job. Now I've read a bit about ripping Blu Rays (legally) on google but the articles can be a bit out of date. It seems some free software+ some paid software is required. But...
What would I need to do this hardware wise..
In particular can anyone suggest a cheap blu ray reader drive?
Keeping cost in mind what sort of processor, motherboard, ram combo would give acceptable results? I haven't set a budget for this. I might feel more comfortable with a smaller outlay so long as the job gets done but don't mind paying extra if the difference is worth it. 350-500.
Is there any other functionality that would be useful? I am aware of how technology is meant to be better, single core, quad core but whether these will make very noticible differences I just don't know.
In the long term I might need a lot of SATA slots so please consider that if recommending a motherboard. I've no plans to game at this stage but if I was to have a sufficiently good system, I might like to add a nice graphics card somewhere down the line. I don't need a suggestion but merely the facility to integrate one should that be required.
A quad core will probally be ok, a fast blu-ray drive.
In terms of storage a blu-ray rip will be about 50Gb ish unless you recode them, in which case a monster CPU will make that whole process quicker
Kimbie
upto 50gig i think
ive tried streaming blue ray off a disc, and that didnt work very well at all :z
you could do a mix of compressed and uncompressed stuff, make the best use of hd space
You could do the encoding on a 1.6ghz atom if you're patient enough. Ages ago I ripped a load of dvds on a 2ghz dual core (t7200 ish), it took a few hours per disk, I queued a load up and left it overnight.
So it seems a reasonable guess that a 2 or 3ghz intel dual core will encode at least one overnight with time to spare. It's only if you want it done fast that you need a quick quad core. You will be needing a blue ray drive though.
More critical is the networking hardware required to stream it reliably, I don't believe wireless will work though 100mbit should do iirc. Home plugs may be an issue if they're in use.
Lots and lots of HDD space
In addition Id suggest this
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail £153.18
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard £71.47
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC) £41.99
Sub Total : £222.20
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 20.00% VAT : £46.34
Total : £278.04
6 core CPU, mobo has integrated gfx to use now, but will also allow addition of dedicated card later
