Blue Ray
21 Feb 2007
Cheshire
Hi, im looking into buying a blue ray player for my pc but i have no idea if my system will support it and what connections i may need etc.
my current system is in my sig, monitor is a LG 22" L226WTQ and has analogue/digital output with native res of 1680x1050.
will my pc support high def movies (blue ray) or will i need t invest into some odd object.
thanks, Sinny.
thanks, Sinny.
As long as you buy a Blueray Player then you should be fine yes.
