Permabanned
- 28 Dec 2009
- london
I just had blue screen and using the nirsoft crash dump reader i can determine that it was the atikmpag.sys which is basically the graphics card crashed.
I have a 7850. I have google the atikmpag.sys and it seems it is quite a common problem. Some people suggest that it is the beta drivers that cause it, one guy said that he upped his voltage and that solved it.
Based on the finalwire aida my voltage for GPU is 0.825, i read that 1.25 is the max recommended. Do you think i should increase the voltage and to what amount?
