ok wonder if any one can give me an idea on this got parts from overclockers
Gigabyte GA-MA785GT-UD3H AMD 785G
Geil Value 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
AMD Phenom II X3 Tri Core 720 Black Edition 2.80GHz
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache boot drive
Samsung EcoGreen F2 1.5TB SATA-II 32MB Cache
Pioneer sata dvd drives
Antec 300 Three Hundred Ultimate Gaming Case
OCZ StealthXStream 500w Silent Power Supply
win 7 oem 64 bit
when i try to use say winrar for instance it gets say half wa ythrough unraring and gives blue screen...there are blue screens appearing when using various programs at different times so cant tie it down to one thing ,all the temps are ok and well within the allowance
the only thing ive done is in the bios changed the memory to dual channel (ganged) mode and the timings to 9 9 9 28 and the timing up to x8 so it runs at 1600 which it should do.....so i am uncertain if its a faulty part if so which one or something else anyone got any ideas thanks.
ok another up date its having problems recognizing usb devices..... like hdd it work before the bsod now it will not find it....put it in another pc and it finds it ok any ideas lol.
win 7 oem 64 bit
