blue screen need help plz
10 Jan 2011
Hello guys,
I've installed windows 7 on my new computer but when I try to do Windows updates it installs around 85% then crashes out with the blue screen,
how do I do a fresh install of windows, as ive tried to do this but it says that it'll still keep old windows files ??
Many Thanks
Was you booting from the disc, there should be a option to format the disc and then install.
Have you tried some stability testing like mem test and prime to ensure your not having a component problem.
Yep, I had a similar problem when I first got my pc and it ended up being one of the sticks of RAM. So, as mentioned above, try mem test.
Sorry for being a doofus but coudl you please link me to the correct page as I googles mem test and there was tons of pages, I've got windows 7 if that helps?
