Blue screen of death every hr help
9 May 2005
Devon
Well title says it all really. every hr or so my comp gets the blue screen of death and i think it says something about my MB bios but it restarts before i can read it. When i restart the comp i get this
ne ideas?
Is it a new build?
I had similar problems, turned out it was faulty memory. RMA'd it and now have no problems at all. Run memtest m8.
You would be supprised m8, i had memory for about 6 months and was convinced it was driver problems, didnt bother even using memtest and it turned out to be fauly memory :)
Try turning off
Control panel -> system -> advanced system settings -> startup and recovery settings -> automatically restart
Should allow you to see the original error
