Blue Screen of death...please help!
10 Nov 2007
Had my system for a year now everything fine (apart from it doesn't like liteon dvd writers...
Anyway my system
MS Windows XP Professional 32-bit SP3
ntel Core i7 2600K @ 3.40GHz
Sandy Bridge 32nm Technology
4.00 GB Dual-Channel DDR3 @ 669MHz (9-9-9-20)
Gigabyte Technology Co., Ltd. Z68XP-UD3 (Socket 1155)
238GB M4-CT256M4SSD2 (SSD)
PIONEER BD-RW BDR-207D
I have changed the ram and still get blue screens, so problem isn't the ram
Bascially i am getting loads of blue screens per day and the computer completely resets in the bios
ACHI changes back to IDE, so i have change again etc
This is the error message
stop 0x000000f4 (0x00000003, 0X88DBD458,0X88DBD5CC,0X805D22DA)
Anyone got any idea's?...guessing motherboard faulty?
I haven't added any new hardware/software recently...
Thanks
Google/Download a free bluescreen viewer, they give far more information than windows does which will help diagnose the issue
I seem to remember having some 0000000f4 blue screens ages ago and i think it was graphics related but I cant be sure, I take it your using onboard as you havent mentionad a g card in your spec?
Trouble shoot it by removing one piece of hardware at a time, like RAM and stuff, also clean all your heatskins out - if they have gathered a lot of dust over the year, your machine could be overheating
Thanks just downloaed it and it listing the intel Graphics drivers in red...see below
Listed the below 4 times
igxpdv32.DLL
And this one once
win32k.sys
Go to your Motherboard's site and check to see if they is display driver updates. Also download chipset updates.
Have you ever installed display update from windows update? that could be an issue.
Another thing I notice you running XP If I was you I would think about going windows 7.
Thanks tried everything now but all i am getting is 15min of PC and then Blue Screen
Anyone think it could be the M4 SSD?
If it is the motherboard is it easy to return with a fault like this?. (never had to return a motherboard before)
Thanks
Just tried bcking uop the hard drive but it failes at the 60% and gives me a disc error...starting to look like the hard drive?
As mentioned in my previous post, check the M4 is running the latest firmware.
Also, check the manual to see what type of port you've connected it, ideally you want it connected to an Intel port in AHCI mode. If you are currently running IDE mode and change it you'll likely cause a BSOD when booting to Windows although I'm sure you know this as you've changed it before. There are plenty of guides about this though. Usually you make a change in Windows before switching the mode in the BIOS. Also to cover all the bases change the SATA cable for another if you have a spare.
Id say windows xp is your problem with all that upto date hardware.
I tried to install xp as a second operating system on my rig like yours upto date hardware and it didnt like it one bit kept BSOD me all the time.
install windows 7 and you will have no more issues
Sorry for the delay, yes thanks it was the firmware
I bought the drive last year and never updated the firmware. I searched google and found there was a known fault with drives with the old firmware. After a certain amount of time they would start powering down. Updated the firmware and perfect now
Many thanks for the all replies
