Hi lads, thanks for taking time to read this. First, the set up
CPU: I5 2500K @ 3.30Ghz
MotherBoard: Asus Z68 V pro-gen 3
GPU: MSI N570GTX Twin Frozr III
Ram: 8G Corsair Vengeance DDR3 1600MHz
PSU: Antec Pro 850
CPU Cooler: Antec Kuhlor H2O 920
HDD: WD 1TB black
SSD: Corsair Force 3 120GB
with Asus DG Xonar PCI 5.1 Audio Card
OS: Win 7 64 bits
First rig mainly for gaming, OC'ed to 4.5Ghz atm, however when pushing up the multiplier to 46, it seems the system won't pass Intel Burn no matter what the CPU voltage i give within the reasonable safe limit. Ran Temtest 86 with ram and no errors, temprature for 4.5ghz is at 52ish under load and 24ish idle. I did not check the dump file when the system blue screen at 4.6 but one thing i noticed is that when I was playing MW3, sometimes during game, the sytem crashes, once even got stuck at the loading screen and had to reboot. Any experts can give any tips that can help me to improve the system stability will be much appreciated.
p.s plz let me know if further infor is required. newbie here
PSU: Antec Pro 850
HDD: WD 1TB black
OS: Win 7 64 bits
i will try it out and get back to you. cheers
