Blue screen once again help needed
28 Aug 2011
Hi all recently build a pc its been fine for around 2 month or so and been gaming but the blue screen happened for a second time yesterday and i managed to take a pic of it any help would be great thanks
Dean
By deano37 at 2011-11-29
off to work so anyhelp i will read tonight not got a clue what could cause this only thin maybe spyware or simething thanks and i will repply tonight
0x000000BE: ATTEMPTED_WRITE_TO_READONLY_MEMORY
A driver attempted to write to read-only memory. Commonly occurs after installing a faulty device driver, system service, or firmware. If a driver file is named in the error message, try to correct the problem by disabling, removing, or rolling back the driver.
Looks like a direct x issue.
You can do the following:
Install KB974431
Install the latest grapichs drivers (Only use the ones from either Nvidia or ATI )
Reinstall DirectX
