Hi,
I have the following set-up
YOUR BASKET
1 x AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor **FREE SIMCITY PC GAME** (AD580KWOHJBOX) £99.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99
1 x Gigabyte F2A85X-D3H AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £68.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £49.99
1 x BitFenix Shinobi "Core" USB3.0 Gaming Case - Black £46.99
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £39.95
1 x Cooler Master 12cm Sickleflow Red LED System Case Fan - (CM-R4-L2R-20AR-R1) £6.98
1 x VTX3D HD 7870 Black Boost Edition 2048MB GDDR5 PCI-Express Graphics Card £155.99
1 x Silverstone Argon SST-AR01 CPU Cooler - 120mm (Socket 775 / 1155 / 1156 / 1150 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £28.99
I was told that the CPU would easily be able to make it to 4.5ghz. I'm currently on 4.1 and it's working fine. As soon as I get it to 4.5 I start to get blue screen errors (often as soon as I reach the desktop after boot, temps are fine). I have all the memory settings set to auto.
Is there anything I need to do?
YOUR BASKET
